Threw a Rod in my Ariens Sno-Thro 6/24 - Snowblower Forum : Snow Blower Forums
post #1 of 46 Old 12-07-2014, 12:36 PM Thread Starter
Hello Folks,
I threw a rod in my Ariens Sno-Thro 6 hp Snow Blower (ran out of oil). Here's what it looks like.. Notice how flimsy the rod is. I had a new rod installed but my engine is burning oil. Going to need new rings. I smell like a oil field. I'am wondering what new engine may I use as a replacement? Or, is my 6 hp worth rebuilding? Can a 8 or 10 hp Tecumseh motor be installed in my snow blower?
All replies will be greatly appreciated.
Richard
Snow Job is offline
post #2 of 46 Old 12-07-2014, 01:06 PM
Koenig041's Avatar
Likes (Received): 11
What a bummer. I know you said you ran out of oil. Were you using natural or synthetic oil?
If you are having someone else do the labor, maybe cheaper to replace the engine. What engine depends on your needs. Some will take the opportunity to go bigger. Some will choose a cloned engine manufactured oversees. Some will just swap out for the same motor.
I personally would stay away from the rebuild. Rings should have been changed when the new rod was put in, they had the thing apart. Do some research on rebuild kits and costs. Get at least 2 estimates from shops. Let us know what you decide.
Koenig041 is offline
post #3 of 46 Old 12-07-2014, 01:35 PM
it would be cheapest to throw a predator 212cc on and bore the main jet a bit. i honestly see no good reason to rebuild a tecumseh flathead anyways. they were hard to start, the carbs sucked, and they loved to throw rods and make unwanted holes in the engine block. a rebuild kit will run about 50 and labor will run about 100, and it may still not run right if the damage dont to the block from the rod blowing up was severe enough
post #4 of 46 Old 12-07-2014, 02:23 PM
Been there myself, bummer. As Koenig said, rings should have been changed when the piston was out. There is also a shaft seal in the intake valve which goes bad which should have been replaced. This may have been your original and continuing problem. These repairs are easy to do yourself, and can be fun if you are so inclined. Check out the videos on youtube by Donyboy 73, which I found through this forum.
Since you have to pull the motor off either way, crack it open and check it out. These guys on here will guide you every step of the way. If you get to a point where a rebuild is not justifiable then order a new engine. Good Luck.
1991 MTD 3/21 SS
1966 Ariens 10M6D
2015 Ariens Platinum 24 SHO
lebenfitti is offline
post #5 of 46 Old 12-07-2014, 03:15 PM
Thanks (Received): 379
Likes (Received): 1377
SLAP a new old stock BRIGGS on it. and call it a day well done.
post #6 of 46 Old 12-07-2014, 07:15 PM Thread Starter
My buddy changed the rod. He also cleaned out the jets. He told me that there was excess oil going into the carb. Oil used was regular 5/20 oil. I think the old girl needs a new engine and carburetor. The Ariens is so well built, that it would be economical just to install a new motor and a rebuilt or new carb. We get an average of about 1 foot of snow every season, of course drifts are bigger.
One issue I found is that since I am 6 feet tall, my back hurts from bending over the snow blower when cleaning snow. Maybe in the future, I may buy a taller snow blower.
Snow Job is offline
post #7 of 46 Old 12-07-2014, 07:20 PM
Thanks (Received): 17
Likes (Received): 79
no, it wouldn't....he can get a complete Tecumseh 7Hp-8hp engine for under $100 on Ebay and simply bolt it on ?
or 5hp
or, 10HP ??
many, many more to choose from...all made in USA
1967 S-242 Snowbird 4/24
Gilson 55012 8/26 gear drive
Ariens 910010 8/32
Cub Cadet 268 8/26
Yard-Man Snowbird 7040-0 5/22
Ariens 10M-L35 3.5/24
greatwhitebuffalo is offline
post #8 of 46 Old 12-07-2014, 07:42 PM
Likes (Received): 16
Before I'd do anything I would put in some 30 weight or maybe some high mileage oil and see if that helps the consumption
cdestuck is offline
post #9 of 46 Old 12-08-2014, 02:07 AM
When your buddy changed the rod did he also clean to rod journal on the crankshaft? When the engine is run with no oil the rod slowly melts and then starts to drop melted aluminum on the crank. As the aluminum builds up it welds the crank and rod together which is what causes them to snap. If he didn't get all the old aluminum off it is just going to do it again.
If the old 6 HP engine is a single shaft engine I would also just grab one of the $100 Harbor Freight 212cc engines and stick it on there.
post #10 of 46 Old 12-08-2014, 07:19 AM
69ariens's Avatar
Thanks (Received): 39
Likes (Given): 53
Likes (Received): 100
Small engine warehouse has 7 hp tecumsehs for like 200 bucks. Web site say they have 83 in stock
Scott
69 ariens
toro 721r
toro 926 hd oxe
69ariens is offline
