Gas mileage/Running time? - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 12-08-2014, 11:54 AM Thread Starter
Just curious if there is a way of knowing in advance of my first time using my snow blower how long it might run on a full tank of E0 gas? The tank capacity is one U.S. gallon.
(i.e. one hour straight, two hours straight)
Mr_Detail is offline
post #2 of 11 Old 12-08-2014, 11:58 AM
TOTHEMAX's Avatar
What snowblower do you have? What HP is the motor?
Ford ST726
TOTHEMAX is offline
post #3 of 11 Old 12-08-2014, 01:37 PM Thread Starter
9 HP Tecumseh. Clean oil, new spark plug. 15 yrs. old
post #4 of 11 Old 12-08-2014, 01:37 PM Thread Starter
Craftsman 26" wide.
post #5 of 11 Old 12-08-2014, 01:39 PM
probably 1 1/2 hours if the carburetors adjusted correctly
post #6 of 11 Old 12-08-2014, 01:39 PM
Normex's Avatar
Likes (Received): 82
Your Tecumseh HMSK90 should last slightly less than 2 hrs and it depends of course on how the engine has to lug namely the type of snow as wet and heavy vs light & fluffy plus the thickness comes into play so you will find out as you work with it. Anyone who has a more definite answer please oblige.
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #7 of 11 Old 12-08-2014, 03:08 PM
Koenig041's Avatar
Likes (Received): 11
They called it right. You are in that 1.5 to 2 hour range depending on work load. Always wondered why they did not put 1.5 to 2 gallon tanks on the throwers with larger motors. Nothing worse than being at the end of the driveway and running out of gas. The buoyancy fuel gauges would have been a nice touch.
Koenig041 is offline
post #8 of 11 Old 12-08-2014, 08:30 PM
Likes (Received): 345
How long
I have a few people I help out due to be widows, divorced, handicapped etc on my block so I usually blow out about 10 houses and if I gas up ahead of time I can do them all and I've not run out of gas yet. In fact I can't remember how many times I've done it without filling.
I've got a 10hp 26" Craftsman custom built machine.
HCBPH is offline
post #9 of 11 Old 12-09-2014, 06:48 AM
Thanks (Received): 17
Likes (Received): 79
all I know is, the bigger the HP rating, the faster it uses the gas. the little 3.5 and 5HP Tec. engines seem to run forever on a tank of gas.
the big 10HP Tec. engine sucked the tank dry in no time.
the higher the HP, the larger the carb bore venture, so the thirstier they are, because more airflow means more fuel being pulled in
1967 S-242 Snowbird 4/24
Gilson 55012 8/26 gear drive
Ariens 910010 8/32
Cub Cadet 268 8/26
Yard-Man Snowbird 7040-0 5/22
Ariens 10M-L35 3.5/24
greatwhitebuffalo is offline
post #10 of 11 Old 12-09-2014, 07:22 AM
Send a message via AIM to SteelyTim
In all my years of snowblowing, I never honestly cared
SteelyTim is offline
