How is snow throw distance calculated, estimated or measured? - Snowblower Forum : Snow Blower Forums
post #1 of 21 Old 12-12-2014, 08:06 PM Thread Starter
Been thinking about this of late.
How is the "throwing distance" of snowblowers calculated or measured?
If calculated - what are the factors taken into consideration? HP of engine, chute angle, auger speed?
If measured - is there a "standard" type of snow, weight/volume/height that is used? Is the chute always pointed forward or to the side?
To be honest with you, I think the majority of snowblowers on the market all throw snow a reasonable distance that makes this specificiation less than useful in real life. Could be wrong though.
I'd love to find out if the "throwing distance" is based on any objective measure or just marketing hyperbole.
miwo76 is offline
post #2 of 21 Old 12-12-2014, 08:25 PM
JRHAWK9's Avatar
Likes (Received): 10
To some throwing distance is important, but I agree, it's mainly just marketing. One can easily figure out impeller tip speed by making a few measurements and knowing the engine RPM to compute the speed at which the snow is actually coming off the impeller at. You can then use this and physics to calculate the theoretical distance it would be thrown when the chute is at a 45 angle (the angle needed to achieve maximum throwing distance). How that compares to real world....who knows.
I think I'm in the real minority, but what's important to me is the rate of which snow is removed. This allows me to normally walk behind the blower and not at a snails pace because the blower isn't capable of discharging the snow at a rate needed for a normal walk.
JRHAWK9 is offline
post #3 of 21 Old 12-12-2014, 08:42 PM
Thanks (Given): 587
Thanks (Received): 767
Likes (Given): 4350
Likes (Received): 1734
Most people will measure with a laser compensated for temperature, elevation and magnetic disturbance and add 5 to 50 feet depending on how proud they are of the machine, new or used.
Sorry, I just had to. Like Jrhawk said " How that compares to real world....who knows."
You can physically measure how far it tosses snow but each snowfall is different in density and depth so it's something that isn't an exact science.
The best way would be to see what a number of owners say they are getting. I'm also a big fan of volume over distance but usually if you have good volume you do get good distance.
Then there is always the blower that's a dog because of it's impeller to wall clearance and with $10-15 in rubber belt and bolts you turn it into a distance champ.
See "impeller mod"
post #4 of 21 Old 12-12-2014, 09:34 PM
Yup...I like that explanation..!!
Here's a video to watch...its not designed as a snowblower, but snow is sure being blown...
Spectacular footage Train plowing through deep snow Arthurs Pass - Safeshare.TV
suspicionofignorance2 is offline
post #5 of 21 Old 12-12-2014, 09:43 PM
question for kissafrog...notice you own a Jacob 626...blown engine...I just bought one...Were you the operator when it blew? Was it governor problem...? My 7hp Tec seems to show a weak tension on Gov..I hope it will control OK...but need snow to check it...it will rev too high when throttle is up...its old..wondering if this is sign..
post #6 of 21 Old 12-12-2014, 10:06 PM
Thanks (Given): 587
Likes (Given): 4350
I wasn't operating it. It was a $15 purchase with the head loose and a tale of no compression. I'm not sure what might be wrong with the engine I'm still trying to take the blower apart and adjust, repair and replace the stuff wrong with the machine. It has some broken welds too. It had the typical worn out drive axle bushings that damaged the chain and a worn out jackshaft and the gears bushings. It had even been flipped once so it was the second time the gear cluster chewed into the shaft. I replaced it with a home made unit. Hope to pull the engine off this spring and go through it or replace it. The side of the block is still good and so is the connecting rod !!
Name:	032714 Imperial 626 in ad.jpg
ID:	31082   Click image for larger version
Name:	040314 JA343474 Disc pivot shaft 2.jpg
post #7 of 21 Old 12-12-2014, 10:25 PM
Spectrum's Avatar
Thanks (Received): 40
Likes (Received): 149
It's the best performance someone in marketing observed or heard of. It may even include a favorable breeze! That's what there is always a YMMV disclaimer.
When I am estimating a working machine I just look for where the stuff is hitting , or actually not hitting virgin snow pack. The short end of the plume is what matters.
Spectrum is offline
post #8 of 21 Old 12-12-2014, 10:51 PM
To me distance is BS. It is what make you happy. Anything beats shoveling snow. Thats just me. To each their own.
bgm961 is offline
post #9 of 21 Old 12-13-2014, 04:33 PM
Coby7's Avatar
Thanks (Received): 123
Likes (Received): 873
Me I just blow it to where it came from and the clouds let fall wherever. Just hope it doesn't fall back in my driveway.
Coby7 is online now
post #10 of 21 Old 12-13-2014, 04:45 PM
Thanks (Received): 17
Likes (Received): 79
no brainer...make a pass and see where the snow lands at is closest point, with the chute cranked all the way to one side for maximum distance, and measure it with a tape measure.
1967 S-242 Snowbird 4/24
Gilson 55012 8/26 gear drive
Ariens 910010 8/32
Cub Cadet 268 8/26
Yard-Man Snowbird 7040-0 5/22
Ariens 10M-L35 3.5/24
greatwhitebuffalo is offline
