Need Help identifying a Bolens Snow Thrower - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 12-17-2014, 12:33 AM Thread Starter
Sblg43's Avatar
Thanks (Received): 11
Likes (Received): 51
I picked up this broken Bolens snow thrower last year and am finally getting a chance to look it over. The engine is a 5HP Tecumseh that runs strong.
It seems that the only thing that doesn't work on this machine, is the front auger blades. The shear pins are intact. So my guess is that the worm gear is damaged.
However, there are no identifying numbers anywhere on the machine that suggest a model number. It seems to be in great shape, except that it can't throw the snow
The engine is a Tecumseh HS50-67257F serial 5233B. Based on the serial number, it appears to be a machine from 1985 or 1995?
Any ideas? Thanks
Sblg43 is offline
post #2 of 5 Old 12-17-2014, 05:04 AM
Thanks (Received): 379
Likes (Received): 1377
I WOULD guess it to be a 1995 model. but I have been wrong before.:ee k:
post #3 of 5 Old 12-25-2014, 08:02 PM Thread Starter
Sblg43's Avatar
I have a friend who had one similar but it was green. His was a Bolens 5210. So I am going to assume that this is close enough to that so that the parts will work.
Bolens 824 (re-powered with Briggs and Stratton 14.5GT snow engine)
Simplicity 860 (1691900-17825) - (Backup machine)
Sblg43 is offline
post #4 of 5 Old 12-25-2014, 09:35 PM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2041
Likes (Received): 517
That's a pretty stout, clean-looking machine.
did you try disconnecting the spark plug, removing the belt cover, engaging the auger and rotating the auger pulley by hand?
('87 Toro 38150 826)
post #5 of 5 Old 12-26-2014, 10:14 PM Thread Starter
Sblg43's Avatar
I pulled the plug on the front auger differential (is that the correct word for it?)
Lots of brass shavings!
Now I have to decide if I want to fix it.
A new brass gear on fleabay and other internet locations is going for $69 - $89.
Since I have so many other working snow throwers, I don't want to keep this one but it seems a shame to scrap it. I will probably fix it and try to sell it.
Sblg43 is offline
