Bob Cat 20" re-do - Snowblower Forum : Snow Blower Forums
post #1 of 19 Old 12-21-2014, 04:10 PM Thread Starter
Bob Cat 20" re-do
I've had this Bob Cat 520 since the mid 1970's, best machine I've ever owned. So about two yr's ago I decided to give it a go-over. One of the things that I never really cared for was the 5hp Briggs flathead with the floatless pumper carb so I found an OHV Briggs on ebay that had the 6:1 reduction box and proceeded to make it fit. Not to difficult, same mount holes just a bit of cutting on the driveside bulkhead to fit the larger gear case, and then fabricate some shrouding to make the engine winter worthy.
While I was into it I fab'ed a new scraper, and changed the impeller shaft and bearings (which as it turned out didn't need to be replaced)
Anyway, this machine with the new OHV engine now runs even stronger than ever, and the low speed operation is far smoother than it was with the pumper carb motor.
Name:	Bobcat R (2).jpg
ID:	32481   Click image for larger version
Name:	Bobcat R (1).jpg
ID:	32489   Click image for larger version
ID:	32497   Click image for larger version
Name:	Bobcat M (2).jpg
ID:	32505   Click image for larger version
Name:	Bobcat M (1).jpg
BobCat520 is offline
post #2 of 19 Old 12-21-2014, 04:16 PM
Thanks (Received): 143
Likes (Received): 297
Nice job, and just out of curiosity, did the original engine have a reduction gear?
post #3 of 19 Old 12-21-2014, 04:16 PM
liftoff1967's Avatar
Thanks (Given): 36
Thanks (Received): 45
Likes (Given): 65
Likes (Received): 94
NICE JOB. Very nice!
liftoff1967 is offline
post #4 of 19 Old 12-21-2014, 04:18 PM
Thanks (Given): 50
Thanks (Received): 76
Likes (Given): 70
Likes (Received): 137
Nice. I never much liked my old Tecumseh either and your modern OHV Briggs will even use less fuel all while making about 2 extra horsepower too. Post a video of it throwing snow. I heard the BOb-Cat machines can really toss the snow.
GustoGuy is offline
post #5 of 19 Old 12-21-2014, 05:03 PM
nice, I have the same one, I have only been able to use it one time since I just got it, my engine runs great though and it threw the slushy wet snow pretty good.
heres mine
Driftbreaker is offline
post #6 of 19 Old 12-21-2014, 05:19 PM
Likes (Given): 1880
Likes (Received): 661
now you have a true modern classic, nice repower
post #7 of 19 Old 12-21-2014, 05:43 PM
GreenMtnMan's Avatar
Thanks (Received): 15
Good job, a Bobcat is on my wish list.
1962 or '63 Snow Bird S-225
1989 John Deere 524
GreenMtnMan is offline
post #8 of 19 Old 12-21-2014, 06:29 PM
The augers on these things always look so flimsy to me by the standards of other machines of that vintage. Has anyone ever had any issues with them getting bent?
post #9 of 19 Old 12-21-2014, 06:32 PM
Thanks (Received): 25
Likes (Given): 81
Likes (Received): 39
Cool machine. Quite the augers.
tinter is offline
post #10 of 19 Old 12-21-2014, 06:59 PM
Likes (Given): 215
Likes (Received): 304
I like it a lot.
I'll bet those augers are twice as thick as any others, and they are welded to fat solid steel bars. Having only one support makes it look flimsy, but I'd still bet you could take a sledge hammer to them and they would be stronger than the typical auger construction.
Then again, I could be wrong.
dbert is online now
