Gearbox oil - Snowblower Forum : Snow Blower Forums
post #1 of 18 Old 12-26-2014, 05:43 PM Thread Starter
Likes (Received): 9
Gearbox oil
Hello all,.
I just decided to mix a little 10w-40 High mileage oil and 80w-90 HD in about an 1:8 ratio. I have been using just 80w-90 for the past couple of years but the seals in my bolens and Toro powershift 6/24 have been leaking it out. I am hoping that the high mileage stuff will help expand the old seals and make them seal properly....
What do you think? Do I have enough protection still with this mix? I have larger engines on both machines so I really don't want to try the grease option and for the life of me cannot find 00 grease locally. I would prefer to keep the oil bath anyway.
Current machines-
1995 Honda HS 621
Buttchet is offline
post #2 of 18 Old 12-26-2014, 07:06 PM
Likes (Received): 82
I doubt this will help any, I would try to torque your gear case bolts and or change gaskets, afraid there is not much options left.
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #3 of 18 Old 12-26-2014, 07:24 PM
Likes (Given): 1887
Likes (Received): 666
found this on ebay
post #4 of 18 Old 12-26-2014, 08:31 PM
Originally Posted by detdrbuzzard View Post
This is cheaper, even after adding $7 flat rate for shipping.
32-9089 - "OO" Grease 1 QT Bottle | Lawn Mower Parts | MFG Supply
post #5 of 18 Old 12-26-2014, 10:18 PM Thread Starter
Likes (Received): 9
Thanks guys. 00 grease on order. However, I will report that my mix is still holding and no leaks so far.
Current machines-
1995 Honda HS 621
Buttchet is offline
post #6 of 18 Old 12-27-2014, 08:57 AM
JD tractor supply, Cornhead lube is usually around 00.
Steering gear box 00 sub was 50/50 mix of axle grease and 80/90 dif oil
MnJim is offline
post #7 of 18 Old 12-27-2014, 09:26 AM
Likes (Received): 303
Tractor Supply sells it locally here in MI.
Think it was $5.
post #8 of 18 Old 12-27-2014, 10:59 AM Thread Starter
Likes (Received): 9
thanks for the info. I ordered the stuff Detdrbuzzard recommended on Amazon last night.
Happy to report that we are on day 2 of my custom mix and no leaks!
Current machines-
1995 Honda HS 621
Buttchet is offline
post #9 of 18 Old 12-27-2014, 12:47 PM
that 00 grease is was I used in my Toro 521, no leaks a year later.
Toro 521 (38052C)
Made in Canada.
ToroGuy is offline
post #10 of 18 Old 12-27-2014, 04:28 PM
Likes (Received): 1383
THE POWERSHIFT uses only 80-90w non sin oil.
