Help me choose a new snowblower Honda vs Yamaha - Snowblower Forum : Snow Blower Forums
post #1 of 25 Old 01-04-2015, 04:55 PM Thread Starter
I am in the process of purchasing a new snowblower for use around my home. I have narrowed down the field to either the Honda HSS928TCD or the Yamaha YS1028J as the best options for me available on the Canadian market. Both of these units have the big features I am looking for: Made in Japan, on board battery for starting, gas assisted auger height adjustment, 28" clearing width, track drive.
Honda HSS928TCD Price: $3,899
Pros:
- Local dealer 5 mins from my home
- Long term parts availability is excellent from Honda
- full electric chute function
- Backup recoil starter
- Lower purchase price
Cons:
- Smaller engine size
- lighter weight may hinder function on built up ice and snow
- the engine is not fully enclosed
Yamaha YS1028J Price: $4,099
Pros:
- Larger engine size
- heavier weight
- Sheet metal used around the auger assembly is much thicker
- The discharge chute is lined to prevent snow buildup
- The engine is fully enclosed
Cons:
- Higher purchase price
- The closest dealer is 2.5 hours from my home
- Parts availability is usually crappy from Yamaha as the unit ages
- the chute control is not fully electric
- no backup recoil starter
So, which unit would you choose and have I missed any important items from my analysis?
mazdarules is offline
post #2 of 25 Old 01-04-2015, 05:34 PM
Thanks (Received): 123
Likes (Given): 43
Likes (Received): 881
Yamaha is quieter too, only parts you'll need are shear bolts so buy them at purchase time if none come with your kit. Are you sure you need a 28"?
Coby7 is online now
post #3 of 25 Old 01-04-2015, 05:37 PM
We don't have yam in the USA but due to your dealer only a few minutes from home I would go Honda.
The yam would probably be a good unit but parts and service look to be scarce... my gut says Honda.
Good luck!
Honda HS 828 (Shoe-less significant restoration)
Honda HS 1132 TAS (simple restoration)
Ariens ST7524E
lclement is offline
post #4 of 25 Old 01-04-2015, 06:36 PM
pfn
Thanks (Given): 13
Likes (Received): 11
Just because of the dealer I go with the Honda but I wouldn't get tracks. I have track and I sooo wish I didn't.
pfn is offline
post #5 of 25 Old 01-04-2015, 06:38 PM
Thanks (Received): 25
Likes (Given): 81
Likes (Received): 39
My Honda is unstoppable. I swear by it, not at it.
tinter is offline
post #6 of 25 Old 01-04-2015, 06:42 PM
Thanks (Received): 238
Likes (Received): 608
Both are fine machines. It might come down to which dealer you would put more trust in.
post #7 of 25 Old 01-04-2015, 08:23 PM
Thanks (Given): 37
Thanks (Received): 70
Likes (Given): 116
Likes (Received): 146
You can't go wrong with either machine. Both machines are beasts and their performance is always best in class. It's the classic "Coke vs. Pepsi" battle. Red or Blue ??? I do think that there's an advantage being close to your dealer in the event something goes wrong or the machine needs servicing. Just comes down to personal preference. Just wish we had access to the Canadian version of the Honda HS928. That electric chute option is sweet.
2009 Honda HS928WAS
2005 Honda HS520AS
1996 Honda HS621AS
2012 Toro 1800 Power-Curve
Freezn is offline
post #8 of 25 Old 01-04-2015, 10:53 PM
Likes (Received): 10
Does the Yammy have a 14" impeller? If so, that would be my choice.
JRHAWK9 is offline
post #9 of 25 Old 01-04-2015, 11:02 PM
Thanks (Given): 51
Thanks (Received): 36
Likes (Received): 63
5 hours round trip if dealer support needed? Maybe you can't get parts for a $4k machine?
Or, local support and availability for parts.
Uh, what's there to think about? The big picture is that the thing's got to work when you need it. Don't sweat the details. Both fine machines.
SnowG is offline
post #10 of 25 Old 01-05-2015, 08:20 AM
pfn
Thanks (Given): 13
If your heart is set on tracks I'm with SnowG.
pfn is offline
