CC to HP - Snowblower Forum : Snow Blower Forums
post #1 of 27 Old 01-05-2015, 07:39 PM Thread Starter
CC to HP
I'm in the market for a new machine,not used to CC...... What ever happened to HP
From what I read you divide CC by 2 then divide that answer by 2 = HP
Today a salesman told a certain machine 420CC was same as 10HP
When I calculate it, it comes out to 13HP, am I wrong on how to calculate.
post #2 of 27 Old 01-05-2015, 07:42 PM
Thanks (Given): 16
[email protected] no your good in your conversion have a look here you'll see your good
Small Engine Cubic Centimetres (cc) to Horse Power Calculator
i have a 420cc engine and was wondering the same what was the HP
cub cadet 3x is offline
post #3 of 27 Old 01-05-2015, 07:56 PM
94EG8's Avatar
Thanks (Received): 48
You can't directly equate CC to HP, it just doesn't work.
94EG8 is offline
post #4 of 27 Old 01-05-2015, 07:58 PM
Normex's Avatar
Likes (Received): 82
+1 with cubcadet but with the same block size the engine manufacturers can vary the HP from 8hp to 13hp with practically the same engine as it all depends on the carb and timing of the engine in question and the output HP the snow blower actually needs. It is confusing a bit but it's all a question of economics for these manufacturers.
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #5 of 27 Old 01-05-2015, 08:27 PM
Likes (Given): 48
Likes (Received): 74
Very true!
That calculator link that was posted is probably pretty close to what a small engine makes given the CCs.
Cub Cadet 2X 524 SWE
caddydaddy is offline
post #6 of 27 Old 01-05-2015, 08:50 PM
The closest answer would be to look up Honda engines. They post CC and HP for most of their GX engines. You also have to remember that over head valve and side valve engines don't compare to each other at all.
As for the reason why, there was a lawsuit about 7 years ago or so from companies fudging their numbers. Now they just use the volume inside the engine.
post #7 of 27 Old 01-05-2015, 10:10 PM
Normex's Avatar
Shryp with Honda aside would you agree that some manufacturers use the same volume for different HP output depending on the need?
Tecumseh had 3 different HP outputs with the 358cc as far as I know.
Many thanks
Normex is offline
post #8 of 27 Old 01-05-2015, 10:56 PM
I agree with 94eg8....The concept is no good...Flatheads, OHV, OHC...At what RPM...Etc...and no mention of Torque....the real measure...Wondering if the calculator would have been more accurate if it converted CC to torque..?
suspicionofignorance2 is offline
post #9 of 27 Old 01-05-2015, 11:08 PM
Coby7's Avatar
Thanks (Received): 118
Likes (Given): 36
Likes (Received): 813
You can convert cc to cubic inches and nothing else.
Coby7 is online now
post #10 of 27 Old 01-05-2015, 11:15 PM
Coby7's Avatar
Likes (Given): 36
420 cc would be a 25 cubic inch.
Coby7 is online now
