Stop-n-go auger, or not?! - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 01-06-2015, 01:01 PM Thread Starter
For those of you with a two-stage snow blower, every time you're not blowing the snow, do you let the auger stop or do you just keep it on? Seems like starting and stopping the auger would stress the belt and other parts.
Fruggy is offline
post #2 of 16 Old 01-06-2015, 01:06 PM
Likes (Given): 1878
Likes (Received): 661
i usually just let the auger spin
post #3 of 16 Old 01-06-2015, 01:20 PM
Normex's Avatar
Likes (Received): 82
It is your choice but where the belts slips when starting it back is if one doesn't wait till all the snow is out when the auger and impeller is stopped.
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #4 of 16 Old 01-06-2015, 08:15 PM
You can throttle the engine down before engaging to save some wear on the belt. Then you are working the throttle a lot. Just leave it spin if you have no reason to stop it. It won't hurt anything.
post #5 of 16 Old 01-06-2015, 10:33 PM
Spectrum's Avatar
Thanks (Received): 40
Likes (Received): 149
Let it keep spinning. Does you manual suggest otherwise?
Pete
Spectrum is offline
post #6 of 16 Old 01-07-2015, 05:12 PM
TOTHEMAX's Avatar
I keep it spinning
Ford ST726
TOTHEMAX is offline
post #7 of 16 Old 01-07-2015, 10:21 PM
I usually keep the auger going with my right hand as that is the one usually steering the blower while I move the chute around or engage the drive with my left hand. It's not a conscious thing, it's just something I end up doing. I stop the drive and let the chute clear before turning around for the next pass so I keep the auger going during that.
RayZor Fist is offline
post #8 of 16 Old 01-08-2015, 06:27 AM
Thanks (Given): 172
Likes (Given): 450
Likes (Received): 1027
I let it keep spinning. Not hurting anything.
post #9 of 16 Old 01-08-2015, 04:03 PM Thread Starter
Ok, guys. But I cannot help it!! I have to stop the auger so I can adjust the discharge chute at every turn!!!!! Now my belt is slipping. I've only ran the engine for about 4 hours cumulative so far!! I'm doubting Troy-Bilt quality.
Fruggy is offline
post #10 of 16 Old 01-09-2015, 10:37 AM
Likes (Received): 345
I'd look for something misaligned (assuming you have the correct belt on it). I've had to start and stop my one machine alot as the auger and drive are controlled by the same cable and it's about 3 years now and still going strong and it was on the machine when I bought it used.
HCBPH is online now
