Benefits to Pre Salting - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 01-06-2015, 03:21 PM Thread Starter
Thanks (Received): 33
Likes (Received): 54
Is there any benefits to pre-salting the driveway pad/ sidewalk, etc prior to a snowstorm . I've never done it as such - just waited till the drifts has slowed down, snowblew/shovel clean and then apply salt.
I recall reading that salt that is laid prior to snowfall does aid in snow removal.
The only benefit I can see is the intial fall of snow that doesn't accumulate but just melts.
Your experiences ?
mobiledynamics is offline
post #2 of 12 Old 01-06-2015, 03:36 PM
Likes (Received): 82
Your experiences ?
I would presume pre-salting would only get diluted with the first few inches. As for myself I would only use it in extreme icing condition as when used on a consistent basis it would corrode a snow blower pretty badly. Just my thought.
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #3 of 12 Old 01-06-2015, 03:54 PM
Thanks (Received): 143
Likes (Received): 297
Agreed, I've found the similar dilution issue, and then in the evening when that solution is so weak it's the first to freeze. The only time I salt is with icy condition, and after I clear the pavement off to keep it a liquid to evaporate quicker.
post #4 of 12 Old 01-06-2015, 05:53 PM
Thanks (Given): 102
Likes (Given): 273
I see the towns and state highway depts. "pre-treating" more and more when they know a big storm is coming. Personally, I apply salt and the like only when absolutely necessary, which isn't too often.
uberT is offline
post #5 of 12 Old 01-06-2015, 06:44 PM
They brine around here, and have even used a beet juice solution in some cities. The pre-salting only occurs when there is a chance of icing.
post #6 of 12 Old 01-06-2015, 07:46 PM
My father in his younger days used to make beet wine, too bad he jumped in the batch before fermentation was complete.
This is good anti icing stuff, maybe they should find a way to crystalize it so we could spread it to our heart's content without any fear of corrosion but only fear of your driveway turning purple.
Normex is offline
post #7 of 12 Old 01-06-2015, 08:04 PM
Thanks (Received): 57
Likes (Given): 425
Likes (Received): 139
What's wrong with a purple driveway or walkway ?
Phil
Ariens 2 foot SHO
1894 is offline
post #8 of 12 Old 01-06-2015, 08:13 PM
Likes (Given): 425
They do a lot of the pre treating roads around here because .... well we are called Salt city ...
Most times it is for an impending snowstorm and when road temps will fall from upper 20's and lower 30's down to the lower 20 F and below range. It just gives the plows a better chance of getting down to bare pavement vs trying to get hard packed ice off the roadways. Timing is critical on that though , as mentioned above .
Phil
Ariens 2 foot SHO
1894 is offline
post #9 of 12 Old 01-06-2015, 08:16 PM
Likes (Received): 15
If you don't mind watching your concrete dissolve into powder, then salt away. Otherwise, clear the snow off the driveway before driving vehicles on it.
happycamper is offline
post #10 of 12 Old 01-06-2015, 08:19 PM
True but salt looses efficiency at 5 deg far and below but the beet mixture isn't affected with temperatures falling well below the 5 deg far mark.
Normex is offline
