if it only - Snowblower Forum : Snow Blower Forums
post #1 of 31 Old 01-06-2015, 04:59 PM Thread Starter
Likes (Given): 1878
Likes (Received): 661
if it only
if it had electric start I would be home with it by now
8hp Ariens Two stage
post #2 of 31 Old 01-06-2015, 05:47 PM
Sid
Thanks (Given): 10
Thanks (Received): 25
Likes (Given): 30
Likes (Received): 43
The flywheel may have teeth. You might just need a starter.
Sid
Sid is offline
post #3 of 31 Old 01-06-2015, 06:01 PM
Likes (Received): 39
That looks in great shape!!!
nt40lanman is offline
post #4 of 31 Old 01-06-2015, 06:07 PM Thread Starter
Likes (Given): 1878
Sid
I would need to know that for sure. I would have no problem adding the starter if the flywheel had teeth
post #5 of 31 Old 01-06-2015, 06:07 PM Thread Starter
Likes (Given): 1878
and the price looks good too
post #6 of 31 Old 01-06-2015, 06:14 PM
joee5's Avatar
Thanks (Given): 17
Thanks (Received): 11
Likes (Received): 12
Price looks GREAT IMO
Toro Snow Commander
Toro Powerlite
joee5 is offline
post #7 of 31 Old 01-06-2015, 07:59 PM
Ray 1962 10ML60's Avatar
Thanks (Given): 24
Thanks (Received): 34
Likes (Given): 15
Likes (Received): 24
William, ask the guy if there is a decal in the engine that says "this engine has provisions for an electric starter" it means there is a toothed flywheel. You also could ask for a pic of the shroud under the gas tank. If there is a bump there for the starter gear you should be good to go and you will just need the starter...
Ray
1962 Ariens 10ML60
1979 Toro 524
1975 MTD Snowflite 4/22
Ray 1962 10ML60 is offline
post #8 of 31 Old 01-06-2015, 08:12 PM Thread Starter
Likes (Given): 1878
i'll send him an email, thanks
post #9 of 31 Old 01-06-2015, 08:17 PM
db9938's Avatar
Thanks (Received): 143
Likes (Received): 297
Heck, just reply to the ad, and ask him. How far away is it from you?
post #10 of 31 Old 01-06-2015, 08:57 PM
For what it's worth, my 10hp Tecumseh has a starter, and I've never used it. Starts easily with just one pull every time. Not suggesting starters are useless, just that I've never used mine. Your mileage may vary.
Toolman_Johnny is offline
