Ariens ST724 w/H70 question - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 01-08-2015, 08:26 AM Thread Starter
Hey Guys - quick question regarding air leaks. Where are some not-so-obvious sources for air leaks on an H70 Sno King? Research tells me that I may have an air leak which is making my blower race, then hunt. I have replaced fuel line, head gasket, breather gasket, O-rings on the carb...still acts like there is an air leak somewhere. Looking to you experts out there for some guidance. Thanks to all....
Uncle Ray is offline
post #2 of 5 Old 01-08-2015, 08:37 AM
Thanks (Received): 379
Likes (Received): 1377
BROTHER GRUNT is the man with the master plan in hand. when it comes to those engines. so when he decides to grace us with a appearance here. you will have your answer that you seek.
post #3 of 5 Old 01-08-2015, 08:39 AM
HJames's Avatar
Likes (Received): 11
Check the gasket between the carb and intake. These symptoms could also be caused by a dirty idle passage in the carb.
HJames is offline
post #4 of 5 Old 01-08-2015, 08:46 AM Thread Starter
Roger that, HJames! Never thought to check the carb gasket. And I will check the passage....makes complete sense. Will do and report back! Thanks again! Uncle Ray
post #5 of 5 Old 01-08-2015, 09:10 AM
clean the main jet, if that doesnt work richen her up a bit with the mixture screw on the bottom of the carb bowl
