Whole bottle of Stab-il in gas tank. - Snowblower Forum : Snow Blower Forums
post #1 of 18 Old 01-08-2015, 04:13 PM Thread Starter
I told my niece to go to the gas station and fill up the 2-gallon jug full of fuel and add stab-il. She's a valedictorian so I assumed she would read the directions, she did not. She added the whole bottle of stab-il.
When I ran the engine, exhaust had a very pungent odor. I've noticed a slight engine power loss at full throttle(full engine power at half-throttle???)
Will this damage my engine?
Fruggy is offline
post #2 of 18 Old 01-08-2015, 04:37 PM
Normex's Avatar
Likes (Received): 82
You are as much at fault as your niece my friend, as you might have asked where the Sta-bil bottle was upon her return?
That being said you have to drain all the snow blower's gas out carb and tank. Now I didn't read the Sta-bil ratio but if you calculate it backwards you can find the amount of gas you need to add or simpler discard safely by adding 1/2 a gal to a full tank to car gas tank at a time then restart with the correct ratio this time. Good Luck
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #3 of 18 Old 01-08-2015, 04:38 PM Thread Starter
I'm guilty, too! Day ruined!!!!!
Fruggy is offline
post #4 of 18 Old 01-08-2015, 04:43 PM
Ariens1976's Avatar
Thanks (Given): 16
Likes (Received): 9
Assumption is ones worst enemy
Ariens1976 is offline
post #5 of 18 Old 01-08-2015, 04:48 PM
Likes (Given): 1878
Likes (Received): 661
your niece sounds like my brother, when he got his snowblower I went over with a bottle of stab-il, an old table spoon and a 3.2oz bottle of two cycle oil and a quart bottle of two cycle oil for his toro ccr 2450.. the empty 3.2oz bottle is his measuring cup for oil and the table spoon is the amount of stab-il to add. to his one gallon gas can
post #6 of 18 Old 01-08-2015, 05:09 PM
Big Ed's Avatar
Thanks (Given): 10
Thanks (Received): 19
Likes (Given): 9
Likes (Received): 59
I add mine before I go to the gas station, maybe that would have been better for you to do.
Too late now.
Do what Normex said and start all over.
I hate shoveling SNOW!
22" Dual Stage
"Classic" 1963 S-226 Snowbird
22" Dual Stage
Big Ed is offline
post #7 of 18 Old 01-08-2015, 05:26 PM
Thanks (Given): 587
Thanks (Received): 767
Likes (Given): 4350
Likes (Received): 1734
It shouldn't do any damage other than maybe soot up the spark plug. It's like running it with too much oil.
You can too it into a car and burn it so it won't go to waste but I'd start from scratch on a new batch for the blower.
I'd run it with what you have and just check the plug when you need to fill it again.
Like Big Ed, I put it in the can before I head to the gas station.
post #8 of 18 Old 01-08-2015, 06:03 PM
scrappy's Avatar
Thanks (Received): 41
Likes (Received): 98
Not sure how old your niece is. Seems about the same age as my kids. The one's that passed all grades with no one left behind BS.
scrappy is online now
post #9 of 18 Old 01-08-2015, 09:44 PM
Likes (Received): 39
Run it!!! Before you know it, the tank will be mostly empty and you can gas it up.
On the other hand, gas is cheap these days....
nt40lanman is offline
post #10 of 18 Old 01-09-2015, 06:22 AM
Thanks (Received): 379
Likes (Received): 1377
IT'S about BLOODY TIME AGAIN!!!!!!!!!!!!!!!!
