MTD Snowblower - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 01-16-2015, 11:19 PM Thread Starter
MTD Snowblower
I have a MTD snowblower. The original carburetor was leaking gas so ordered a new carburetor online from an authorized Tecumseh dealer. After verifying the carburetor was the same, swapped out the old carburetor with the new one. Now the red throttle lever won't move the throttle butterfly. Looks like the linkage is not long enough. Are there different lengths of linkages? Any suggestions?
Gdishinger is offline
post #2 of 5 Old 01-17-2015, 12:28 AM
Normex's Avatar
Likes (Received): 82
Welcome to the forum, as for the carb, can you not take the linkage if any from the old and put on the new. Pictures would help and or more info on your unit.
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #3 of 5 Old 01-17-2015, 04:57 AM
joee5's Avatar
Thanks (Given): 17
Thanks (Received): 11
Likes (Received): 12
Welcome from the Garden State
Toro Snow Commander
Toro Powerlite
joee5 is offline
post #4 of 5 Old 01-17-2015, 08:31 AM Thread Starter
The new carb didn't come with a new linkage. Thank you for your help.
post #5 of 5 Old 01-17-2015, 10:03 AM
Motor City's Avatar
Thanks (Received): 53
Likes (Received): 65
It sounds like you have the linkage wrong. The rod from the govenor goes to the middle hole on the throttle lever on the carb. It would help if you can provide what size Tecumseh your working on. The pic's I attached are an 8hp
ID:	36273   Click image for larger version
Ariens ST11528LE
Honda HS720
Motor City is online now
