Ariens Ax Engines - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 01-17-2015, 09:31 PM Thread Starter
BeerGhost's Avatar
Likes (Received): 11
Ariens Ax Engines
Do the LCT engines have a cast iron or steel bore ?
BeerGhost is offline
post #2 of 17 Old 01-17-2015, 09:46 PM
they are build just like the honda gxs which they are cloned from, which has a castiron bore and dual ball bearings on each side of the crankshaft
post #3 of 17 Old 01-17-2015, 09:54 PM
Normex's Avatar
Likes (Received): 82
LCT engines have a cast iron sleeve and two bearings for the crank, hope this helps you.
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #4 of 17 Old 01-17-2015, 10:06 PM Thread Starter
BeerGhost's Avatar
Thanks guys
I seen the new Briggs Have a "Kool bore" so I am thinking that is an aluminum bore?
How does it hold up with steel rings rubbing it?
post #5 of 17 Old 01-17-2015, 10:16 PM
Normex's Avatar
Thanks guys
Of course an aluminum bore is less durable to heat temperatures that snow blowers may encounter when the temps are in the forties and if the oil gets dirty if not changed as per the engine manual.
Normex is offline
post #6 of 17 Old 01-18-2015, 09:48 AM
AriensSnowman's Avatar
Likes (Received): 8
Thanks guys
Any of the new Briggs don't hold up period. They are destroying their brand with the quality of the engines they have been producing. The repair shop I do welding for has told me some of their engines come with plastic valve guides! Their shop has more Briggs than any other brand in it by a big margin.
AriensSnowman is offline
post #7 of 17 Old 01-18-2015, 03:07 PM
GustoGuy's Avatar
Thanks (Given): 50
Thanks (Received): 76
Likes (Given): 70
Likes (Received): 137
That is too bad. Must be a CEO cost cutting decision so he can pay himself much more money. Look at LCT Chinese engines. They seem to be holding up well and are on the Ariens machines. Also look at the Chinese made Loncin engines used by Toro seem to hold up well. The problem with American companies is American Bureaucracy and American board of director cheapness. Cut money and destroy the reputation of the company only to destroy American jobs so they can move even more stuff overseas than they have already did. Yes I know Briggs engines are made in China. The Board of directors is using cost cutting measures to ensure more short-term profit for themselves. A corporate raider is a better term for these people.
GustoGuy is offline
post #8 of 17 Old 01-18-2015, 03:36 PM
Thanks (Given): 72
Thanks (Received): 397
Likes (Given): 182
Likes (Received): 928
I blame the American consumer more than corporate management.
the corporations move production to China as a *reaction* to the American consumer demanding everything be cheaper and cheaper and cheaper..
Walmart also plays a major role in all of this.
and a clarification: Ariens AX engines are not Honda clones.
post #9 of 17 Old 01-18-2015, 04:31 PM
they are technically clone engines scott but are heavily modified with changes to the bore and connecting rod and a ton of shrouding, and a slighty different carb.
post #10 of 17 Old 01-18-2015, 04:43 PM
Thanks (Given): 72
Likes (Given): 182
That is incorrect..technically they are not clone engines. They are not Honda clones, or clones of anything, they are LCT's own design.
