Serrated Auger - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 01-19-2015, 09:15 PM Thread Starter
Post Serrated Auger
Has anyone tried cutting serrations into an auger that did not have any?
Or tried welding some teeth to improve hard packed snow performance?
Cheers
candive is offline
post #2 of 7 Old 01-19-2015, 10:50 PM
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3334
Likes (Received): 679
I tried searching for the post and couldn't find it. Someone went to a big box store and traced the serrations on a piece of paper and then used a hand held grinder to cut the serrations into their augers. Some people think they help with EOD piles, some people don't think it matters. Your choice.
post #3 of 7 Old 01-20-2015, 12:04 AM
Thanks (Given): 51
Thanks (Received): 36
Likes (Received): 63
I suspect it helps but frankly if the ice is hard enough that you can't sheer it off with the spiral, then it might be time to get out your grub axe and break up the mound (if you really want to move it).
You've got to get it soon while it's fresh. If you let it freeze hard you're screwed.
SnowG is offline
post #4 of 7 Old 01-20-2015, 10:22 AM
I would think if the ice is thick enough that he augers cant easily break it up. Then it may be harmful to the augers and the system. Time to break out a tool and help break it up.
Ford ST726
TOTHEMAX is offline
post #5 of 7 Old 01-20-2015, 01:07 PM
Sid
Thanks (Given): 10
Thanks (Received): 25
Likes (Given): 30
Likes (Received): 43
Yeah I cut three tapering notches in my Sears/Murray augers. The material is 1/8' thick [old steel], I don't know if it works or not. I would think that it cut the icy, hard, packed EOD material, better than non serrated augers. It is worth a shot, in the warm wether.
Sid
Sid is offline
post #6 of 7 Old 01-21-2015, 05:22 PM
Thanks (Received): 28
Likes (Received): 107
I personally do not care to have them. When I used a friends machine that had them, I just touched the corner of my neighbors "wooden" stairs and it caused the bolt to break. Way too sensitive with having the cuts in the augers. Not nescessary for me especially for how often we get a build up of ice chunks in the front apron area. If we do, the good old "ice chopper" comes out and I get a good old fashion work out.
Kielbasa is offline
post #7 of 7 Old 01-22-2015, 09:11 AM
Sid
Thanks (Given): 10
Likes (Given): 30
Yeah they will raise h**l with your stairs, or steps. I know personally.
Sid
Sid is offline
