Impeller kit - Snowblower Forum : Snow Blower Forums
post #1 of 19 Old 01-28-2015, 09:43 AM Thread Starter
Thanks (Received): 19
Likes (Given): 23
Likes (Received): 62
Impeller kit
Since i'm the new guy to snowblowers and a bit green. I hear this
talk of impeller kits. Never seen one, Have a vague idea as to what
it will do. Where can one buy this kit and are they universal to fit
any blower. How difficult to install and are there any pic's on this site.
I looked a bit but found nothing yet.
Thanks Lee
lee h is offline
post #2 of 19 Old 01-28-2015, 10:08 AM
Thanks (Given): 170
Thanks (Received): 306
Likes (Given): 432
Likes (Received): 1018
http://smllengns.tripod.com/id13.html
Lots of us have made our own kits out of baler belt material and small pieces of steel. Not at all hard to make but not the most fun to install. Not complicated, just not fun.
post #3 of 19 Old 01-28-2015, 11:10 AM
What kind of blower do you have?
1999-Craftsman 536. 9/26-gone
2011-Simplicity-I1224E
Simplicity is offline
post #4 of 19 Old 01-28-2015, 01:49 PM
jermar's Avatar
Likes (Received): 13
It's easy to make your own. I used a worn single stage rubber edge.
jermar is offline
post #5 of 19 Old 01-29-2015, 09:01 PM Thread Starter
Likes (Given): 23
Thanks guys, looks like a very simple job and easy to make.
One question, Doe's the rubber fold over the impeller or just
till it hits the housing. hard to tell in the pic's.
Thanks Lee
lee h is offline
post #6 of 19 Old 01-29-2015, 09:16 PM
Just put it so it barely touches the housing.
post #7 of 19 Old 01-29-2015, 09:39 PM
Thanks (Given): 7
Likes (Received): 6
how do you install it? do you remove the impeller from it or do you install it through the outlet?
2019 Ariens Platinum 24 SHO Carb (921050)
1995 Ariens ST724E (932027) - For Sale
chapel is offline
post #8 of 19 Old 01-29-2015, 10:07 PM
90trunk's Avatar
Thanks (Given): 10
Thumbs up
I have done 3 MTD installs through the chute opening. New or sharp drill bits make the job easier.
Regards,
Craig
'99 Honda HS621
'05 MTD/Troy-Bilt 26"-8.5hp
90trunk is offline
post #9 of 19 Old 01-29-2015, 10:10 PM
Thanks (Given): 229
Thanks (Received): 199
Likes (Given): 2030
Likes (Received): 516
Prior to fastening, It helps to clamp it to the impeller and rotate it to find the tightest spot in the housing.
Impeller Mod (I cheated and bought the kit on eBay)
('87 Toro 38150 826)
classiccat is online now
post #10 of 19 Old 01-30-2015, 01:14 AM
Thanks (Given): 67
Thanks (Received): 60
Likes (Given): 115
Likes (Received): 81
Originally Posted by micah68kj View Post
HOW IT WORKS
SNOWBLOWER IMPELLER KIT
Just curious....About how thick is the Baler belt you guys have used?
I know there is a guy on you tube who used self tapping screws but I would not recommend that on something that spins so fast, is in a high rust and abrasive environment.
Use at least a 1/4 bolts with nylock nuts. Grade 8 or Stainless steel if you can. They are less apt to rust and are much tougher.
Current machines
Ariens 926LE
Toro-8-2-4 is offline
