warm restart choke or no choke? - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 02-02-2015, 09:15 PM Thread Starter
I ran out of fuel and when I went to restart it gave me a bit of a hard time. When in restart how many pumps on primer bulb and should I use choke?
wantboost is offline
post #2 of 9 Old 02-02-2015, 09:19 PM
Thanks (Given): 224
Thanks (Received): 294
Likes (Given): 1847
Likes (Received): 644
most snowblowers don't need to be primed or choked if the engine is warm
post #3 of 9 Old 02-02-2015, 09:43 PM
AL-
AL-'s Avatar
Thanks (Given): 7
Likes (Received): 29
If you had shut it off and tried to restart it, it would normally start without being primed.
So, if you factor in running out of gas then that seems to make a difference. Now that you have it gassed up and running you could shut it off and then try to start it and see if it behaves differently. If your problem is running out off gas makes it quite difficult to start then keep an eye on the gas tank level to avoid the problem. If your carburetor has not been cleaned in awhile that might be part of the problem. Most people now days due to the 10% ethanol added to gas add a stabilizer/cleaner additive to their gas. You could check your spark plug gap and also see if it's clean
AL- is offline
post #4 of 9 Old 02-03-2015, 12:03 AM
Thanks (Given): 169
Thanks (Received): 305
Likes (Given): 421
Likes (Received): 1012
Hmm... I can never restart mine without at least choking them. Not like a rototiller or lawn mower.
But, to answer your question..., whatever works. There is no set method. Machines vary'also.
post #5 of 9 Old 02-03-2015, 05:53 AM
Likes (Received): 12
I agree on the ethanol gas and I simply use Indian Hi Test for all my small engines so I don't need to be tearing carbs apart constantly . The other trick with ethanol gas in small engines i have hear recommended is to run the carb dry every time you use it and it will be sitting for a while. Definitely when it's being laid up for the season. Of course for daily use it would probably drive you nuts unless you have electric start.
A guy I know is a boat wrench and his marina swears by that new Stabil Ethanol treatment. It seemed to solve most problems with small outboards and stop the constant carb cleaning. It's cheap insurance for how much gas a blower goes through as is high test.
2002 Ariens 932-101
driz is offline
post #6 of 9 Old 06-24-2015, 10:10 PM Thread Starter
Even with a fuel shutoff u can't really run dry since fuel stays in the float?? Or not
post #7 of 9 Old 06-25-2015, 03:24 AM
if you have to restart it and theres gas in the tank you shouldnt have to choke it or pprime it. if you have to add gas it might be a different story but with my honda gx390 on my Landa power washer when it runs out of gas you just fill it wait a minute for the carb to fill up and pull the cord and she will go first pull with no choke
post #8 of 9 Old 06-25-2015, 01:33 PM
Thanks (Given): 572
Thanks (Received): 743
Likes (Given): 4218
Likes (Received): 1639
There will be some fuel in the float bowl as the engine doesn't suck it all out but "running it dry" uses up a lot of fuel that would otherwise sit in that bowl over the months and break down. If you're putting it away for a season it would be good to run it dry and then drain or pull the float bowl and wipe it out.
I don't go that far, just run it dry and hope that by using non-alcohol, stabilizer and a fuel cleaner I'll be good to go in a few months. It's worked so far.
post #9 of 9 Old 06-25-2015, 02:45 PM
knu2xs's Avatar
Thanks (Given): 133
Thanks (Received): 125
Likes (Given): 286
Likes (Received): 145
The above pretty much sums up my experience over the years.
Last fall was no exception when I bought a new, 2014, Ariens
Platinum 24 SHO, that "cold starts" on the first or second pull
(choke, full throttle & a few primer pumps.)
After trying many combinations for "warm starts" I found that,
no choke, half throttle, 2 hits on the primer, worked like a charm.
knu2xs is offline
