Gravel driveway - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 02-12-2015, 10:32 PM Thread Starter
Gravel driveway
Ariens sno-tek 920404
What happens if/when pebbles/gravel from driveway get into snowblower? I am scared to death of them and have made custom wooden skids to get my blade about 3” off the ground. The municipal trucks w/plows sometimes toss some pebbles along with snow into driveway when passing by, and pebbles can appear in driveway after hand shoveling a clear path to house from garage. . . anyway . .my question is, can small pebbles/gravel (average 3/8”) damage snowblower?
RickGP is offline
post #2 of 13 Old 02-12-2015, 10:40 PM
Spectrum's Avatar
Thanks (Received): 40
Likes (Received): 149
It should take it in stride. I have 12,000 square feet of crushed geravel with stone up to 3/4" some of that gets chucked especially when the ground is soft.
Spectrum is offline
post #3 of 13 Old 02-12-2015, 11:02 PM
Thanks (Given): 10
It's the windows on your house, and your cars, you need to worry about!
Saewoody is offline
post #4 of 13 Old 02-13-2015, 09:09 AM
Likes (Received): 1347
they will put a dent or two in the machine. and your wallet.:ro lleyes:
post #5 of 13 Old 02-13-2015, 09:18 AM
Thanks (Given): 170
Thanks (Received): 305
Likes (Given): 431
Likes (Received): 1017
Had an old MTD I used, to clear a 150 yd. gravel driveway. Never hurt the machine but the occasional rock would be sent into orbit. As was said, be more concerned for windows etc than your blower.
post #6 of 13 Old 02-13-2015, 05:59 PM
RoyP's Avatar
Likes (Given): 7
What happens if/when pebbles/gravel from driveway get into snowblower? I am scared to death of them and have made custom wooden skids to get my blade about 3 off the ground. The municipal trucks w/plows sometimes toss some pebbles along with snow into driveway when passing by, and pebbles can appear in driveway after hand shoveling a clear path to house from garage. . . anyway . .my question is, can small pebbles/gravel (average 3/8) damage snowblower?
This is my impeller housing after the previous owner thru stones with it.
Name:	Impeller housing.jpg
RoyP is offline
post #7 of 13 Old 02-13-2015, 07:22 PM
And for the extreme cases:
https://www.snowblowerforum.com/forum...ck-damage.html
post #8 of 13 Old 02-13-2015, 07:41 PM
Thanks (Given): 573
Thanks (Received): 749
Likes (Given): 4246
Likes (Received): 1679
You need to have it 3/4" up and let the ground freeze. That 3/4" is what works for me and I never blow in the direction of the house. I'm lucky, I don't have neighbors so I don't have to worry about that.
At 3" you're just leaving way too much behind IMHO. I also upgraded to stock Ariens skids on my Troy which are a little wider which help "float" it on top of the gravel instead of it digging in.
If you have the time and skills, you can also go with lawnmower wheels as some have done.
Name:	Skid replacement with mower wheels.jpg
ID:	41529   Click image for larger version
Name:	111213 Troybilt Storm2410 Skid upgrade 1.jpg
post #9 of 13 Old 02-14-2015, 09:13 AM Thread Starter
WOW! a lot of info here . . just wanna thank all you guys for being so helpful.
RickGP is offline
post #10 of 13 Old 02-14-2015, 09:32 AM
AriensSnowman's Avatar
Likes (Received): 8
You need Armor Skids ideally for gravel, because it will smooth out the unevenness on the surface and float better. Stock skids like to dig in. Approximately 7/8" height on the wear bar is about perfect. 3" is insane. You'll get some chipped paint, but that's normal wear and tear.
Ariens Platinum 30 SHO
AriensSnowman is offline
