Drift Cutter Mod - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 02-20-2015, 08:29 AM Thread Starter
Likes (Given): 7
Post Drift Cutter Mod
I can't seem to find a thread I once read about how to make drift cutters usable without needing any tools. Anyone know where it might be?
2012 Craftsman Professional 30" 357cc
Model # 247.888301
Heated Grips, Clarence's Impeller Kit
Chuck2 is offline
post #2 of 14 Old 02-20-2015, 09:17 AM
Thanks (Received): 238
Likes (Received): 606
This isn't the one you were thinking of, but Ken05 just started this one this morning. There's mention of using chain saw bars that you don't have to drill.
https://www.snowblowerforum.com/forum...tter-bars.html
Thanks Chuck2 thanked for this post
post #3 of 14 Old 02-20-2015, 09:26 AM
Thanks (Received): 18
Likes (Received): 27
Grab a couple of the Areins ones. very slick design, can put them up or down with no tools and gloves on in about 30 seconds a side
Ariens Pro Hydro 28 Rapidtrak
Toro 2450
Toro 3650
Toro powerclear 1800
bkwudz is offline
post #4 of 14 Old 02-20-2015, 12:24 PM
+1
Plus, they are $20-30 and match the machine perfectly. Making them would be a waste of time imo.
Tachead is offline
post #5 of 14 Old 02-20-2015, 02:37 PM
Thanks (Given): 573
Thanks (Received): 749
Likes (Given): 4246
Likes (Received): 1679
I made my own and used stainless fasteners and I like them more than "store bought", cheaper too.
post #6 of 14 Old 02-20-2015, 05:38 PM
Thanks (Received): 29
Likes (Received): 66
Made my own as well- Very useful thing to add. But.. I'm going to change mine so they either pivot back or get slotted to drop down and back. Unless you use every few days (not happening here in Wi.) I find myself bumping into them when walking by the blower. catch my coat. I want them so they will be easy to just put in place within a minute or two just when ready to use. Mine are made with 1/8" x 2" flat steel. P.S. as others said- they do help in deep snow.
Geno is offline
post #7 of 14 Old 02-20-2015, 10:02 PM
Thanks (Given): 33
Thanks (Received): 37
Likes (Given): 64
Likes (Received): 87
I plan on making my own for both of my Ariens machines because I have a fair amount of 1/2" x 1-1/2" 6061-T651 aluminum stock, an Alliant/Prototrak CNC milling machine, a pair of Kurt 6" vises, lots of tooling and love to carve up metal!
I haven't decided yet just what to use for fasteners. I want something which needs no tools to slide the drift cutters up & down and wing nuts aren't fancy enough. Whatever I use must be "low profile" so they don't stick up, yet should be able to loosen and tighten with gloves on. I may just make my own out of 316 stainless steel so they don't bind or rust.
2015 Ariens Deluxe 28+ 921037, 414cc LCT (now son's)
2014 Ariens Platinum 30 921029, 414cc LCT (mine forever)
PixMan is offline
post #8 of 14 Old 02-20-2015, 10:51 PM
Thanks (Given): 67
Thanks (Received): 60
Likes (Given): 115
Likes (Received): 81
How about carriage bolts with hand knobs?
Current machines
Ariens 926LE
Toro-8-2-4 is offline
Likes Chuck2 liked this post
post #9 of 14 Old 02-20-2015, 11:06 PM
Coby7's Avatar
Thanks (Received): 116
Likes (Given): 32
Likes (Received): 773
My Yamaha drift cutter design works well.
Coby7 is online now
post #10 of 14 Old 02-21-2015, 09:23 AM
Thanks (Given): 33
Likes (Given): 64
Thanks, but I generally go for something far more fancy than that. You have to understand that someone who is a "home shop machinist" (on top of doing it for a living) will have the tendency to make for tens or hundreds of dollars and hours of work, something you could buy for a buck or two.
I'm not quite that bad but do want something nicer here. Before I start I'm going to see if someone near me has the Ariens kit so I could get measurements of the slots and bolt pattern on the bars themselves. The goal is to come up with something a little fancier than factory, but not having any fasteners that would stick out any further than what the factory offers.
I'd love to see some detailed photos of how the factory ones are fastened onto a late model Deluxe or Platinum.
PixMan is offline
