Re:cooking spray application results, wet, heavy snow - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 02-24-2015, 10:02 PM Thread Starter
oldgeezer's Avatar
After reading on here regarding the application of cooking spray to chute, impeller, auger, never done it.
Well recently heavy, wet rain/snow up here and figured I'd try it out with my 95 toro 824.
Well to whomever who may not have either had to try this or may need to in future,
and I can tell you, it works!
0 clogging, and must say, it wasn't just 'in my head', but viewing others using their snowblowers, same day, same storm, my toro was shooting just as far as stated in articles read here without an issue, and did witness neighbors without their 'typical distance' I've witnessed previous.
Thus, not just my opinion, but clearly this mod does help.
Just sharing...
oldgeezer is offline
Thanks Ray 1962 10ML60, micah68kj thanked for this post
post #2 of 12 Old 02-24-2015, 10:17 PM
Ray 1962 10ML60's Avatar
Thanks (Given): 24
Thanks (Received): 34
Likes (Given): 15
Likes (Received): 24
Cool, going to try it out next snow.
Ray
1962 Ariens 10ML60
1979 Toro 524
1975 MTD Snowflite 4/22
Ray 1962 10ML60 is offline
post #3 of 12 Old 02-25-2015, 10:17 AM
Thanks (Given): 14
Thanks (Received): 28
Likes (Given): 19
Likes (Received): 21
Also consider Fluid Film which is lanolin based spray on corrosion protector. Snow doesn't like to stick to it and the surface is coated until you power wash it off. Stops rust in its tracks.
____________________________
1989 Bolens 5210 R 21" - 5 hp 2 stage -- Impeller kit worked wonders
1983 Honda single stage -- HS 35 single stage -- still going strong
Prof100 is offline
post #4 of 12 Old 02-25-2015, 10:22 AM
Thanks (Received): 238
Likes (Received): 606
Thanks for that review.
post #5 of 12 Old 02-25-2015, 11:06 AM
Thanks (Given): 14
Thanks (Received): 17
Likes (Given): 36
Likes (Received): 31
Has anyone tried the WD40 w/ silicone lubricant? I picked up a 2 pack recently. One can of the regular WD40 and one can of WD40 silicone lubricant.
When i recently replaced the differential trigger lock cable, i cleaned up the gear mechanism and sprayed it with the stuff, but never tried it for the impeller/chute.
250cc B&S (1150 ft lbs)
Loco-diablo is offline
post #6 of 12 Old 02-25-2015, 11:16 AM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 308
I'm not sure how valid this is since most of the snow we've had this year has been pretty dry, but I've been using this stuff:
...with excellent results. No sign of anything that even resembles a clog.
It's available from many different sources - Google "Dupont silicone teflon spray".
ELaw is online now
post #7 of 12 Old 02-25-2015, 01:59 PM
Thanks (Given): 170
Thanks (Received): 306
Likes (Given): 432
Likes (Received): 1018
Just sharing...
I have been using cheap cooking spray for years on my shovels and snowblower buckets, augers, chutes and impellers. Not going to buy high dollar stuff when the low dollar stuff does what I need it to do. Food Lion snowblower spray!
post #8 of 12 Old 02-27-2015, 09:31 AM
Kielbasa's Avatar
Likes (Received): 106
I am just not a fan of putting anything gooey or wet on to my machine. This is why I use the car wax method. But over this summer season, I am going to look in to the ski wax method.
One thing that I have done differently over this winter season is that I have put extra coats of wax on the inside of the chute and exit hole before each snow storm just to make sure that I will not have any problems, rather then just when I think of it. I even put another coat on all of the pieces that face upwards so that the snow will fall off. Like on the dashboard, top of the chute and deflector and bucket. I think that I could actually remove the exit hole clearing tool and brackets off of my machine now, but............ you just never know................
Kielbasa is online now
post #9 of 12 Old 02-28-2015, 12:16 AM
Likes (Received): 16
Ski wax is probably not a good idea as it's primary purpose is traction. It is temperature dependant. You would hope the snow isn't the type that you applied so it does slide and not grab.
kueh is offline
post #10 of 12 Old 02-28-2015, 09:53 AM
Kielbasa's Avatar
That is a very good point. Thanks! Two heads or more, are always better then one. I will probably just stay with the Meguiar's Gold Class paste wax because it works, it's simple, doesn't take a lot of effort and it leaves the machine looking pretty good.
