Snowblower switch not working - Snowblower Forum : Snow Blower Forums
post #1 of 21 Old 03-05-2015, 09:47 PM Thread Starter
Hello all. I have an older True Value Snow Chief - 21 inch, 3hp Snowblower. When I attempt turn it off it still runs. I know it maybe fruitless trying to locate a new switch , so I was considering putting in a toggle switch. There is only a green wire going to the switch. If i were to use a toggle switch, how would I hook it up? Would I have to hook the green wire to the positive side and make a ground to the body and hook it up to the negative side? Any help would be appreciated. Thanks in advance.
Levaughn is offline
post #2 of 21 Old 03-05-2015, 09:51 PM
The switch doesn't care about polarity but yes, that's how you would wire it.
Shorting the "green" wire to the frame will kill the ignition.
What does the current switch look like?
AandPDan is offline
post #3 of 21 Old 03-05-2015, 10:03 PM
Thanks (Given): 564
Thanks (Received): 742
Likes (Given): 4200
Likes (Received): 1634
Try to get something weather resistant as a "normal" switch from an auto parts store, big box, hardware ... is likely designed to be inside.
NTE 54-527W Waterproof Rocker Switch SPST : Rocker Switches | RadioShack.com
Or a toggle switch with the rubber cover
Likes Grunt liked this post
post #4 of 21 Old 03-05-2015, 10:18 PM Thread Starter
Thanks for the input. The old switch has a short key. I can't really describe it cause I'm not too familiar with switches. I will seek out a waterproof switch
Levaughn is offline
post #5 of 21 Old 03-05-2015, 10:32 PM
Thanks (Given): 167
Thanks (Received): 301
Likes (Given): 416
Likes (Received): 1007
Doesn't matter at all how you wire it. One way it'll run the other way it won't. Heck. If you wanted to you could even use a light switch like you have in your house.
post #6 of 21 Old 03-05-2015, 10:35 PM
scrappy's Avatar
Thanks (Received): 41
Likes (Given): 41
Likes (Received): 94
Old school.. kill switch.
It works... Fail rate is 0 for every 100,000,000 ever made.
Name:	kill switch.JPG
scrappy is offline
post #7 of 21 Old 03-05-2015, 10:36 PM
Thanks (Given): 564
Likes (Given): 4200
I've never understood why they use key switches (children??) but it's likely a standard diameter and you could if you wanted, get one from any other brand snowblower. Just take yours in with you to compare diameter.
I'd just go with the toggle or you could eliminate the wire and just use the throttle if the throttle still kills the engine. You have options
post #8 of 21 Old 03-05-2015, 10:46 PM
Thanks (Received): 29
Likes (Received): 66
Lev.. The two prong toggle really isn't a + and - per say, You can hook the green wire to either side and other side to ground. The on/off plate won't be right so just discard. I 'might' have a used original.. I use to have a one-wire key switch. It just grounds the green wire when in 'off' through the housing and into frame where it is mounted. Usually uses big star type washer when mounted.
Geno is offline
post #9 of 21 Old 03-05-2015, 11:06 PM
Thanks (Given): 564
Likes (Given): 4200
Or . . . if you like those little touches, take a file or a Dremel and grind off the little tab so you can rotate the plate to line up with the switches "ON" and "OFF"
post #10 of 21 Old 03-05-2015, 11:25 PM
to turn it off for now, choke the engine and prime it until it stalls
