Hello from Westchester, NY Need help choosing a blower - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 03-08-2015, 12:28 AM Thread Starter
Hi,A newbie here, I'm hoping I can get a little help. I am the furthest thing from a motor head. I just destroyed my first snowblower by not checking the oil (yes, stupid me)and it's seized up. The repair shop tells me it's not worth fixing. It's too bad because it was fine for my needs. It was a Craftsman 28" with tracks. I got it used and had it four seasons. I have a long driveway, maybe a tenth of a mile, and then it winds around the house and gets real wide when it gets to the two car carport, so even the oil truck can turn around. And it's got two pretty steep hills, and both bend, and both are where the sun never shines. The local shop that told me the machine isn't worth fixing also says I don't need tracks. They've seen it when they picked it up. Whadya think? Wheels with chains will work?
And whadya think about this?
SNOW BLOWER MTD 10HP 33"PATH
or this?
Snow Blower
Thanks all, for any advice.
Canoejon is offline
post #2 of 17 Old 03-08-2015, 12:36 AM
knu2xs's Avatar
Thanks (Given): 133
Thanks (Received): 125
Likes (Given): 286
Likes (Received): 145
Hello Canoejon, sorry I can't be of any help, but I can offer you a hearty, WELCOME ABOARD!!
knu2xs is offline
post #3 of 17 Old 03-08-2015, 01:41 AM
Thanks (Given): 573
Thanks (Received): 750
Likes (Given): 4247
Likes (Received): 1683
Welcome to the forum Canoejon
If your drive is fairly flat you might be better served with tires and no chains. Depending on the hills tires should be ok but how did you feel using the tracks ?? Newer tires have very good grip and the chains tend to shake the machine.
They might not think it's worth putting an engine on it but you could always sell it to someone on Craigslist who does.
That 10hp 33" is likely damaged. It looks like the piece of wood on it's left side is to reinforce the bucket from it bending.
That and the augers are on backwards so it would be pushing snow to the sides of the bucket instead of to the center and out the impeller
Whoever buys it has to pull the auger/impeller assembly out of it and swap those augers.
The MTD is a lighter duty, homeowner machine but the price vs it's condition looks like a much better deal.
The Yellow monster is likely a little heavier construction but I'd be worried who's been using it, how it's been maintained and who the clutz was that put the augers on backwards.
If they were both $200 I'd lean more towards the MTD snowflite.
I'd suggest looking for a good used Toro or Ariens. At $600 you might even run into a Honda.
post #4 of 17 Old 03-08-2015, 03:23 AM
Thanks (Given): 30
Thanks (Received): 40
+1 on the vote for a good used Toro or Ariens... and add Simplicity to that list, the ones with model 860/870 style frame (squareish tubing leading up to handlegrips) they are nicely built machines. Throw a set of tire chains on one and it will do well.
The meltdown is under way ...
05' Toro 3650/ 6.5 RTek
Pathfinder13 is offline
post #5 of 17 Old 03-08-2015, 07:35 AM
time2time's Avatar
Likes (Received): 27
For quality brands, there is a HATS acronym, which stands for Honda, Ariens, Toro, and Snapper / Simplicity. Craftsman is generally viewed here as middling quality, and MTD doesn't get a lot of love here. Personally, I like Toro because it is good quality and there are a lot of them on the used market, but that is my personal take.
If we are really done with the snow for the season (as i hope for the area) prices will likely tumble in the coming months, if cost and value are important to you. Where in Westchester are you located? Generally a little more snow if you are north of 287, and another step up in snow as you get to 84.
Toro 3650 (primary)
Toro 2450 (recent purchase)
Toro PowerLite (3hp)
Craftsman 3/20 (also recent, will likely flip)
Toro 1800 electric (gone)
Shovels (and aspirin)
time2time is offline
Likes RoyP liked this post
post #6 of 17 Old 03-08-2015, 09:26 AM
Likes (Received): 1351
get the BLOODY yellow 1. ALOHA from the paradise city. here in the unfrozen TUNDRA.
post #7 of 17 Old 03-08-2015, 09:57 AM
Thanks (Given): 230
Thanks (Received): 199
Likes (Given): 2034
Likes (Received): 516
Welcome to SBF neighbor! (I'm across the River in Orange county).
+1 on what the other guys said already.
this one pops-up in our area:
Toro 828 Powershift (Briggs) for $500...been on the market awhile, bet you can get him down a bit especially with it being the end of the season.
('87 Toro 38150 826)
classiccat is online now
Likes detdrbuzzard, POWERSHIFT93 liked this post
post #8 of 17 Old 03-08-2015, 10:14 AM
joee5's Avatar
Thanks (Given): 17
Thanks (Received): 11
Likes (Received): 12
Welcome from the Garden State
Toro Snow Commander
Toro Powerlite
joee5 is offline
post #9 of 17 Old 03-08-2015, 10:49 AM
Thanks (Given): 146
Thanks (Received): 325
Likes (Given): 431
Likes (Received): 783
Welcome! Sorry to hear your other machine died.
What kind of snow do you get, and how much at a time? Storms that are 4" of fluffy snow would let you get away with a wide bucket, and low power (say 32", 8hp, if anyone made that combo). If you get 12" of wet heavy snow, you will want more power, and you may still need a narrower bucket, to avoid overwhelming the machine (say 26-28", 10hp+).
What is your budget, roughly?
Does your driveway get icy? How did the tracks do for you so far, in terms of traction?
There are a lot more wheeled machines on the market than tracked. I use chains on my tires, I don't have any complaints about traction, even when it gets icy.
Kiss4aFrog is right about the augers appearing to be backwards on the big yellow beast. Unless they rotate in the opposite direction to most machines, which is probably possible, though quite uncommon, I believe. Most machines have the front of the augers rotating down, so they should screw the snow in, towards the middle of the machine.
I'll second the HATS suggestion. Ariens and Toro make very good machines, and they are more common, and cheaper, than Honda and Simplicity.
I had a used mid-90's MTD, 8hp, 26". It was good, and I used it for about 10 years. But I bought a used Ariens ST824 (8hp, 24") after that, and was impressed with the differences. Thicker steel, better designed and built, bigger augers, bigger impeller, and a differential to make turning easy. I now have another used Ariens, which I'm also very happy with.
The red MTD in the CL ad has very small augers. As Kiss4aFrog said, it strikes me as an inexpensive, home-use type machine. Whereas you have a lot to clear. Big augers and a big impeller will help process & throw more snow.
Do also consider support and parts availability. The big yellow beast may be a less common machine. If documentation is tough to find, you may have difficulty figuring out replacement parts, and/or buying them. I'm sure Toro is similar, but manuals and parts support for Ariens machines, even old ones from the 60s-70s, is very good. An awesome machine, brought down by a part you can't obtain, is unfortunate.
post #10 of 17 Old 03-08-2015, 10:54 AM
Thanks (Given): 224
Thanks (Received): 294
Likes (Given): 1863
Likes (Received): 648
hello jon, welcome to SBF!! don't get the yellow one, it has problems and pass on the craftsman and get something a bit more heavy duty. the end of snowblower season is near so you have all spring, summer, and fall to find something better
