Chute Extensions - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 03-10-2015, 03:21 PM Thread Starter
Thanks (Given): 14
Thanks (Received): 28
Likes (Given): 19
Likes (Received): 21
Chute Extensions
I searched chute extension kits and got a 2011 thread on impeller kits. So, I started this thread to ask if anybody makes a chute extension assuming longer is better?
No need to post about lubricants or Teflon lining. That is not the question.
Bill
____________________________
1989 Bolens 5210 R 21" - 5 hp 2 stage -- Impeller kit worked wonders
1983 Honda single stage -- HS 35 single stage -- still going strong
Prof100 is offline
post #2 of 13 Old 03-10-2015, 04:06 PM
Blue Hill's Avatar
Thanks (Received): 52
Likes (Given): 266
Likes (Received): 108
Bill
I did a search too Prof and found this thread:
https://www.snowblowerforum.com/forum...00-series.html
It sounds like Husqvarna makes an add on extension and there's a picture too. Doesn't look like it would be too hard to make. It sounds like the theory behind it is to get more of the fine powder away from the operator.
Larry
Snow Removal Equipment:
2014 Ariens Platinum 24
Blue Hill is offline
post #3 of 13 Old 03-10-2015, 06:47 PM
Likes (Received): 39
That extender looks like it would compact the stream making it go further.
I'd love to change my stubby chute for something long and lean, and add that extender to get snow further. I'm always blowing upwind so further away means less coming back at me.
nt40lanman is offline
post #4 of 13 Old 03-10-2015, 07:43 PM
Jackmels's Avatar
Thanks (Received): 194
Likes (Given): 466
Likes (Received): 811
Perhaps something like these Coveted Tall ones?
http://s14.postimg.org/4ey1osnbl/004.jpg
Jackmels is offline
post #5 of 13 Old 03-10-2015, 08:58 PM
RoyP's Avatar
Likes (Given): 7
Bill
Here is my chute lining.....works great. I took a plastic pail, cut it to fit the chute, used 1/2" counter sunk screw with teflon lock nuts.
Name:	blower chute.JPG
RoyP is offline
post #6 of 13 Old 03-10-2015, 09:05 PM
RoyP's Avatar
Likes (Given): 7
That's a nice extension. thank you I may try that
RoyP is offline
post #7 of 13 Old 03-10-2015, 10:53 PM
Spectrum's Avatar
Thanks (Received): 40
Likes (Received): 149
I'd focus first on compacting the chute from the base up to maintain pressure and force velocity.
Spectrum is offline
post #8 of 13 Old 03-11-2015, 09:35 AM
Zavie's Avatar
Thanks (Given): 71
Thanks (Received): 118
Likes (Given): 562
Likes (Received): 259
I ended up installing the chute extension on my Husqvarna. With the holes already in place in the deflector it was so easy. I ordered just the extension itself and figured I could fabricate the metal support bars. On the factory installed versions I've seen online it looks like they used rivets to mount. I used stainless hardware that I purchased locally. Since I never used the machine without the extension I don't have a before and after story to tell. However I never had an issue, even in strong winds with blowing snow, where I could not put the snow where I wanted to.
2016 Ariens Professional 28
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is offline
post #9 of 13 Old 03-11-2015, 10:03 AM Thread Starter
Thanks (Given): 14
Likes (Given): 19
That looks pretty good. It looks like it is a piece of some black plastic roll that's about .10" thick or less. I used similar plastic material on my race car. It could be cut and formed with a heat gun make an extension. The material is 24 inches wide. I could even make it quick detachable with Dzus fasteners. Or, just simply screw it in place and be done with it.
Prof100 is offline
post #10 of 13 Old 03-11-2015, 10:29 AM
Zavie's Avatar
Thanks (Given): 71
Likes (Given): 562
You are right on with the thickness. As far as the material it is flexible yet when mounted it is stiff enough to maintain it's shape. Not sure what the material is. It seems like rubber, but does not smell like rubber. Might be a silicone based material. One thing, this does add some weight to the deflector so at first the deflector with extension made the assembly a bit bouncy over bumps. On my machine I adjusted the tension adjusting nut on the deflector spring and all was normal again.
Zavie is offline
