Upgrading your snowblower lights to LED lights - Page 133 - Snowblower Forum : Snow Blower Forums
post #1321 of 1357 Old 03-04-2019, 01:44 PM
tabora's Avatar
Thanks (Given): 43
Thanks (Received): 220
Likes (Given): 129
Likes (Received): 421
Originally Posted by Ddub View Post
I tapped into the original headlight wiring and yeah.. 2 seasons now.. No problems.
You haven't mentioned what make/model blower you have, but that's listed as a DC-only light, so you must have a machine that generates DC - you lucked out.
tabora is online now
post #1322 of 1357 Old 03-09-2019, 10:37 AM
DC LED lights will work when powered by AC but it's not as the manufacturer intended. AC swings both positive (DC) and negative. You just won't be delivering full power to them (only 50% duty cycle) and depending upon how the LED light is designed you might do damage over time since you are exceeding spec. Some DC lights have rectifiers circuitry built in, hard to tell unless advertised. The best way to tell if you are overloading a circuit is to measure the in-line current (amps) will light is on with volt/amp meter. If you don't know how to do that you can just measure the voltage (volts) at the DC LED light terminals while running (light is on). If it maintains the 12V's then your stator is keeping up with things. If it's dropping to 8-10V then its being burdened and not a good situation but still will light up. At $20 cost for LED light you can just replace if/after it burns outs but not as easy if the stator gets damaged.
jtreveloni is offline
post #1323 of 1357 Old 03-09-2019, 10:41 AM
I documented my LED upgrade (see below link). Might have some info you are looking for. But this only applies to my 2018 Ariens Platinum 30 blower. If different then you got to measure. https://www.dropbox.com/s/7qbegrrqux...grade.pdf?dl=0
Likes JohnnyB, Bakeram1 liked this post
post #1324 of 1357 Old 04-07-2019, 12:52 AM
Originally Posted by muddywrangler View Post
Could the stator be damaged, or anything else damaged if I run too high of wattage.
Yes, you can burn up a stator. I should have taken a picture of what a melted 18 watt stator looks like before I pitched it out. The moral of that story was that in line fuses are much cheaper and far easier to replace than stators. I went 2 winters with no lights because I decided to use two 18 watt lights which actually worked well for about 5 hours before it smoked the stator lol.
1999 MTD (Mastercraft) 10.5 HP 29" (Restored 2014)
Snow Joe SJ624e (for the deck)
1979 Toro 824 (fully restored)
2017 Husqvarna (shouldn’t have bought it)
Edgy1 is offline
post #1325 of 1357 Old 10-07-2019, 04:06 PM
Likes (Received): 23
Any new inexpensive LED spot or flood fixtures on the market that wire directly w/o additional circuitry?
Also, why doesn't the stock wiring on an Ariens have a fuse? Are fuses only needed when you add an LED?
trellis is offline
post #1326 of 1357 Old 10-07-2019, 05:42 PM
Likes (Given): 38
Likes (Received): 243
Fuses are pretty much personal preference. Anal people will always put them in, and lazy people won't. I feel that are optional and not needed
Guess I am lazy.
RIT333 is online now
post #1327 of 1357 Old 10-10-2019, 08:51 AM
cub cadet light upgrade 18W or more?
I have a cub cadet model : 31AH6ZK4596 serial : 1l028l30067. Motor Briggs & Stratton family 8BSXS.3422SW. Build date 07 08. No heating grip.
The incandescent light (18W) is dead and I want replace with 2 led like Auxbeam LED Light Bar 4" 18W, with rectifier, capacitors…..
How to know the capacity of watt that can I plug. I want 18W x 2. I don’t want dommage the stator. I can go safe with 18W but if I can go more I will going
Thank you
jblkiller is offline
post #1328 of 1357 Old 10-10-2019, 09:10 AM
oneacer's Avatar
Thanks (Received): 136
Likes (Received): 484
Wow, you'll be lit up for sure with those bad boys ...
oneacer is online now
post #1329 of 1357 Old 10-10-2019, 11:15 PM
tabora's Avatar
Thanks (Given): 43
Likes (Given): 129
I installed a set of those on my Toro Zero Turn mower. They actually draw a fraction of 18W, so you should be OK.
https://www.mylawnmowerforum.com/for...tml#post586037
Thanks jblkiller thanked for this post
Likes jblkiller liked this post
post #1330 of 1357 Old 10-11-2019, 09:12 AM
Nice one, Keep up the good work man.
Sasablad is offline
