Filling tires with expanding foam (flat free) - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 11-09-2016, 04:27 PM Thread Starter
e.fisher26's Avatar
Thanks (Received): 46
Likes (Given): 43
Likes (Received): 59
Watched a lot of YouTube on this. Seems to be easy, but not a lot on how it lasts. Has anyone here done it?
Sent from my iPad using Tapatalk
e.fisher26 is online now
post #2 of 9 Old 11-10-2016, 01:51 PM
Sid
Thanks (Given): 10
Thanks (Received): 25
Likes (Given): 28
Likes (Received): 39
Yeah, I would be curious about that also.
Sid
'66 Sears/Murray 26"
'71 Jakobson 17 SnowBlitz
Sid is online now
post #3 of 9 Old 11-10-2016, 02:04 PM
Thanks (Received): 15
Likes (Received): 58
Foam seems soft. I'd be concerned that they would develop dents.
CO Snow is offline
post #4 of 9 Old 11-10-2016, 02:08 PM Thread Starter
e.fisher26's Avatar
Likes (Given): 43
The science behind seems to be the holes/cracks are sealed, so if no holes are drilled and u fill from the nozzle with shrader valve (or however it's spelled) removed, air can be added possibly... also the trick is make sure water is added into tire before and halfway through process to keepfoam activating and curing hard as possible
post #5 of 9 Old 11-10-2016, 02:09 PM Thread Starter
e.fisher26's Avatar
Likes (Given): 43
Or holes are drilled at flat spots and foam added later
post #6 of 9 Old 11-10-2016, 05:04 PM
Likes (Received): 279
Poly filled tires are much better as they ad considerably more weight....... kinda expensive but you'll never need to do it again.
post #7 of 9 Old 11-10-2016, 06:24 PM
Thanks (Given): 77
Thanks (Received): 160
Likes (Given): 395
Likes (Received): 631
.......im kinda partial to good ol air in my tires.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
post #8 of 9 Old 11-11-2016, 11:00 AM
Thanks (Given): 13
Thanks (Received): 123
Likes (Given): 144
Likes (Received): 284
I usually use Green Slime in all power equipment tires, Seems to seal all small leaks and hold preasure through the seasons, Mower had it 3 yrs before it needed more air and 2 of the tires needed to be filled every week before that.
Dauntae is online now
post #9 of 9 Old 11-11-2016, 11:06 AM Thread Starter
e.fisher26's Avatar
Likes (Given): 43
I hear lock-tite has a expansion foam that's more dense and flexible
