Modified chute - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 01-19-2019, 05:22 PM Thread Starter
Modified chute
I finished modifying the newer chute from Honda. I added UHMW plastic lining and collar. I liked the idea when I saw it on the Yamaha’s.
ID:	151895   Click image for larger version
ID:	151897   Click image for larger version
ID:	151899   Click image for larger version
John445 is offline
post #2 of 17 Old 01-19-2019, 05:28 PM
Thanks (Received): 87
Likes (Given): 96
Likes (Received): 230
Nice work, Where did you source the UHMW and what thickness, May try that on a Ariens I will be rebuilding for next year.
Dauntae is online now
post #3 of 17 Old 01-19-2019, 06:39 PM Thread Starter
Thanks, I used this company and hear are the different thicknesses.
ID:	151911   Click image for larger version
John445 is offline
Likes aldfam4 liked this post
post #4 of 17 Old 01-19-2019, 06:49 PM
aldfam4's Avatar
Thanks (Given): 186
Thanks (Received): 36
Likes (Given): 497
Likes (Received): 94
Nice work, thanks for posting. Did you get a chance to see how it works yet?
Ariens - 924086 - ST1028
Craftsman - 88934 - 10HP 28"
Toro - CCR 3650
Toro - CCR 2000
aldfam4 is online now
post #5 of 17 Old 01-20-2019, 03:24 PM Thread Starter
No sign of the chute clogging, if it were to clog, today would be the day. It’s mostly due to the impeller kit my friend Dan from this site has fabricated.
John445 is offline
post #6 of 17 Old 01-20-2019, 04:57 PM
Thanks (Given): 48
Thanks (Received): 26
Likes (Given): 71
Likes (Received): 105
@John445
I'm a tad confused now. Doesn't the rubber at the bottom in these pics essentially recreate the same chute design issue the new design was supposed to eliminate?
Peter
Honda HSS724ACTD, HS520 and HS720CC.
"Perfection is an insult to the Gods."
CalgaryPT is offline
Likes FullThrottle liked this post
post #7 of 17 Old 01-20-2019, 05:15 PM
Thanks (Given): 30
Thanks (Received): 128
Likes (Given): 65
Likes (Received): 219
Originally Posted by CalgaryPT View Post
@John445
No, totally different angle more parallel to the flow, like the Yamaha as he said. Looks like a great solution! I was going to attach the UHMW with velcro strips, but I like what he's done. I think I may use DZUS fasteners for quick removal.
ID:	151991   Click image for larger version
ID:	151993   Click image for larger version
tabora is online now
post #8 of 17 Old 01-20-2019, 05:27 PM
Thanks (Given): 29
Thanks (Received): 131
Likes (Given): 185
Likes (Received): 279
Lining looks good. My concern would be how well the adhesive holds up. Yamaha has the mechanical attachment and the one piece molded liner that I wish every manufacturer would adopt.
dbert is online now
post #9 of 17 Old 01-20-2019, 07:22 PM
Likes (Received): 8
Not sure what the benefit is. I have the new chute and so far I have not had the old clogging issues nor have I noticed any snow being thrown any differently. When you added this mod, what changed for you?
Bob_S is offline
post #10 of 17 Old 01-20-2019, 07:52 PM
drmerdp's Avatar
Thanks (Received): 140
Likes (Given): 24
Likes (Received): 290
Ive had modified collar and peel and stick 1/32" UHMW in my chute for a couple years.
I sealed the edges of the material with clear RTV. Works like a charm, holds up great.
drmerdp is offline
