Good question, I’ve seen other brands that are clearly running lean, and could use a rejet.
Also, I’ve searched but cannot find documentation that other brands engines are CARB approved. (The strictest emission standards.) Honda has is plastered front and center on their websites engine descriptions.
The most obvious reason for rejetting is less then optimal power output. This is the most apparent from the Honda snowblowers due to extremely fast impeller speeds which requires the gearing to be quite tall, and in turn puts the engine under more load and stress than other brands that are generally using shorter gearing with slower impeller speeds.
As an example, my refurbed simplicity with a 301cc predator engine has an Impeller speed of 941rpms and I cannot get the engine to bog down no matter how hard I try. If I regear the drive pulley to deliver 1200rpms you can bet I’ll get the 301 to bog down.
Couple that with hydrostatic drive which doesn’t have set gears, and the lack of awareness of the amount of forward speed being used. Most are resistant to slowing down a bit, and hair triggered to exclaim that “Honda’s are underpowered”
The competition for the most part is using larger CC Honda clones and generally lower impeller speeds.
