Honda HS760TS - Joy-Stick issue - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 08-10-2019, 04:22 PM Thread Starter
I recently bought a snow blower with some issues. Most of them are solved now, but one remain.
The joy-stick is only controling the snow discharge chute works in only in two of four directions. (Rotate works, but the deflector is not moving)
I have swapped the wires and established that both actuators/motors are working.
This means that something is wrong in the wiring/electrical components between battery and motor....
Does anyone have a wiring diagram, or perhaps better, a good suggestion of how this problem may be corrected ?
Where can I order spareparts to this old model (from 2006)
Best regards Per Inge
peringe is offline
post #2 of 4 Old 08-10-2019, 05:42 PM
leonz's Avatar
Thanks (Given): 72
Thanks (Received): 86
Likes (Given): 75
Likes (Received): 153
It sounds like dirty or burned contacts if the switch is a low voltage momentary switch.
Have you looked at the honda site to see if a manual is available? I think all you need is the
serial number of the machine to enable you to down load a copy.
leonz is offline
post #3 of 4 Old 08-13-2019, 06:30 PM
vmax29's Avatar
Thanks (Given): 17
Thanks (Received): 25
Likes (Received): 81
If I remember correctly people were having problems with some of the joysticks. I would just replace it outright.
If your inclined to rip into it a can of spray electrical parts cleaner might do it. I had a propane Mr. Heater fan stop working. I traced it to the switch. After taking the switch apart I found moth worms made a nest in the contacts! I never would have believed it. The silk from their nest was enough to break the contact. Bug bombs are your friend when storing stuff. I stored birdseed in the shed and the critters were from there. So you never know what you might find when you get into these electrical pieces / parts.
vmax29 is online now
post #4 of 4 Old 08-14-2019, 07:30 AM
orangputeh's Avatar
Thanks (Given): 625
Thanks (Received): 152
Likes (Given): 913
Likes (Received): 980
This is a warranty issue . honda should take care of it if still under warranty. Oh, I see this is a 2006 model? I thought these did not come out until 2015.
"It Feels Like Beer O'Clock "
orangputeh is online now
