HAS1332ACTD warranty work, TSB's - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 10-08-2019, 11:46 AM Thread Starter
btm
Hey,
Taking my has1332actd in for some work this week before the warranty expires.
The chute control acts up, I know there is a TSB for that, anyone have it handy?
The auger handle no longer stays locked I have to hold it down or else it disengages. There's a TSB for that also if you guys know it?
I'm not 100% sure if it slows down much after repetitive forwards/backwards movement related to the transmission, but I may get them to install the tranny fluid res anyways. There's a TSB for that also?
And it's running pretty lean I need to keep the choke partially pulled out so I'll have that taken care of.
At the same time I'll get them to do a 108 or 110 jet but not sure which I should go with?
The new chute design I won't bother with because I know how to use the machine and it only clogs if I'm an idiot with it lol.
Thanks guys!!
Sent from my Pixel 3 XL using Tapatalk
btm is offline
post #2 of 5 Old 10-08-2019, 03:22 PM
Miles's Avatar
Thanks (Given): 83
Thanks (Received): 61
Likes (Given): 355
Likes (Received): 178
Yes, there is a TSB for the early models of the HSS series due to cavitation in the fluid and a transmission reservoir is the solution. I know that Robert's posts here on the forum discussed many of these technical service bulletins, but I am not sure how to find this information.
Honda HSS928AWD (upgraded chute, transmission)
Honda HS720AS (at sister's)
Honda EU2000i (generator)
Miles is online now
post #3 of 5 Old 10-08-2019, 05:40 PM
tabora's Avatar
Thanks (Given): 43
Thanks (Received): 230
Likes (Given): 132
Likes (Received): 434
Note: these are USA service bulletins; looks like you're in Canada based on your model number...
The chute controls problem is just a standard warranty coverage item.
Ground Speed Service Bulletin: https://www.snowblowerforum.com/foru...714-post1.html
Interlock Service Bulletin: https://www.snowblowerforum.com/foru...354-post1.html
Chute Service Bulletin: https://www.snowblowerforum.com/foru...589-post1.html
Jet depends on altitude: 110 @ sea level; 108 at anything up to a few thousand feet; 105 above 4000 feet; stock 102 above 7000 feet (all give or take temperature - your experience may vary).
tabora is online now
post #4 of 5 Old 10-09-2019, 11:59 AM Thread Starter
btm
So I am between 200-300ft above sea level. It's pretty cold here sometimes, easily -20c for a month straight (-4f) so should I go with the 108 or the 110?
btm is offline
post #5 of 5 Old 10-09-2019, 02:10 PM
tabora's Avatar
Thanks (Given): 43
Likes (Given): 132
I guess that I would try the #108 first, based on the experience of others farther above sea level than I am. See @jrom's post here, for example: https://www.snowblowerforum.com/foru...1-post771.html
