Honda HSS724AW Which Fumoto Valve? - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 10-08-2019, 06:10 PM Thread Starter
SkunkyLawnmowers's Avatar
Location: Brit girl from London now in the Blue Ridge Mountains
Thanks (Given): 30
Thanks (Received): 35
Likes (Given): 62
Likes (Received): 122
Hi,
I hope you're all doing good.
It must be getting near that time of year again as I am about to service Parker, my faithful snowblower! I'm treating him to a Fumoto valve.
I need to confirm exactly which model fits him. I believe it will be the F124 series, 10mm x 1.25 pitch. Honda GX200 engine.
Could anyone who has fitted one please confirm that's the right size?
'Parker' Honda 2017 HSS724AWD
'Puffer' 2011 Toro 1 Stage
'Jen' Honda EM6500 generator
'Tilly' Honda Mantis tiller
Remember the 7 Ps - Proper Planning Preparation Prevents P Poor Performance
SkunkyLawnmowers is online now
post #2 of 11 Old 10-08-2019, 07:12 PM Thread Starter
Thanks (Given): 30
Likes (Given): 62
I'm thinking the F124 because that fits a 10mm x 1.25 bore which is the specification of the Honda part no. 90131ZE1000 which is listed as the oil drain plug for my model - and for all the other USA HSS series models, too.
post #3 of 11 Old 10-08-2019, 07:16 PM
Miles's Avatar
Thanks (Given): 83
Thanks (Received): 61
Likes (Given): 352
Likes (Received): 178
Hi! A lot of people like this drainzit hose:
Regards, Miles
p.s. Here is another website that validates your specs:
https://www.oildrainvalve.net/ez-oil...124-10mm-1-25/
I looked under industrial engines:Honda to get to this page of the website
Honda HSS928AWD (upgraded chute, transmission)
Honda HS720AS (at sister's)
Honda EU2000i (generator)
Miles is online now
Thanks SkunkyLawnmowers thanked for this post
post #4 of 11 Old 10-08-2019, 07:34 PM
tabora's Avatar
Thanks (Given): 43
Thanks (Received): 224
Likes (Given): 132
Likes (Received): 425
Yes, on the HSS724AW, the drain bolt is listed as 90131-ZE1-000 which is 10mm, but if you're putting it on the end of the extension (10mm x 8mm), that bolt is 90103-KN8-000 which is 8mm. If you go with the F124 and no extension, you'll probably have to unmount the engine (or at least loosen the mounting bolts) in order to screw it on, or find another extender that's 10mm x 10mm. I used the 12mm Drainzit on my HSS1332ATD for that reason.
tabora is online now
post #5 of 11 Old 10-08-2019, 10:17 PM
orangputeh's Avatar
Thanks (Given): 746
Thanks (Received): 223
Likes (Given): 1499
Likes (Received): 1482
dranzit hoses are easy to use. lift up blower on drain side and support with wood. then screw in. extension just as good.
6 of 1 , half dozen of the other.
"It Feels Like Beer O'Clock "
orangputeh is online now
post #6 of 11 Old 10-09-2019, 10:57 AM Thread Starter
Thanks (Given): 30
Likes (Given): 62
Hi tabora
Thanks for your input.
What I don't understand - I'm probably missing something - is why you used a 12mm Drainzit when your drain plug is listed 10mm (90131-ZE1-000) the same as mine?
post #7 of 11 Old 10-09-2019, 11:27 AM Thread Starter
Thanks (Given): 30
Likes (Given): 62
Thanks everyone for your replies and input, it is appreciated.
I'm going to go with the Drainzit. I have Fumotos on all my other engines and they work brilliantly but I have noted the space restrictions for fitting a Fumoto on the smaller engines such as Parker has.
I even found a pink one
post #8 of 11 Old 10-09-2019, 01:58 PM
tabora's Avatar
Thanks (Given): 43
Likes (Given): 132
Actually, the GX390 uses 90131-896-650 BOLT, DRAIN PLUG (12X15). The one you listed is the 10mm one that goes on the end of the Honda drain extension. The extension is 12mm x 10mm. Why Honda extensions always step down one size remains a mystery.
post #9 of 11 Old 10-09-2019, 02:15 PM Thread Starter
Thanks (Given): 30
Likes (Given): 62
Interesting, because when I was comparing what size bolts other Honda HSS blowers have, they all said it was the 90131-ZE1-000. So it looks like they are listing the wrong part number (at least for your machine).
Name:	honda parts 2.JPG
post #10 of 11 Old 10-09-2019, 03:08 PM
tabora's Avatar
Thanks (Given): 43
Likes (Given): 132
No, it's #4 in the diagram (circled in red). The one you're looking at is #5, which goes into the extension tube and is in fact the 10mm drain plug for your machine, while the equivalent bolt on your extension is 8mm.
