Honda HS928 Track - Drive Clutch Lever - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 01-19-2020, 01:06 PM Thread Starter
Have a 4 year old HS928 that won't move. Runs fine, auger engage is fine. Drive handle/lever is loose. No tension. There appeared to be a pin missing from under the handle that goes through the shaft connecting to the auger engage handle. The replacement pin went right in through the shaft but I'm guessing it needs to line up somehow? Or do I have bigger problems? Is there somewhere I can buy a svc manual to download? Any tips would be appreciated!
iowaboy is offline
post #2 of 4 Old 01-19-2020, 02:59 PM
orangputeh's Avatar
Thanks (Given): 746
Thanks (Received): 223
Likes (Given): 1495
Likes (Received): 1477
perhaps a broken cable end or the end came out of the slot? is there a way to post picture? when the handle is loose like that it is usually a broken cable that i check first. the cable is also connected underneath the belt cover to a spring that sometimes the end breaks on spring.
"It Feels Like Beer O'Clock "
orangputeh is online now
Thanks iowaboy thanked for this post
post #3 of 4 Old 01-19-2020, 06:16 PM Thread Starter
Thank you so much orangputeh! It was indeed the cable. i had some snow get in behind that spring cover yesterday & froze overnight. When I went to engage today the spring popped off. Everything was there & in tact.
Great help again -- thank you!!
iowaboy is offline
post #4 of 4 Old 01-19-2020, 08:22 PM
orangputeh's Avatar
Thanks (Given): 746
Likes (Given): 1495
actually I'd be wondering why it popped off. very unusual. maybe needs a cable adjustment when you get it back into slot? or the cable froze in sheaf?
you can pull the boot off and spray some chain/cable spray and work it so cable does not bind up. if boot is off then you are getting water in there .
