Carb leak after jetting change - Snowblower Forum : Snow Blower Forums
post #1 of 25 Unread 01-24-2020, 01:22 PM Thread Starter
Brand new machine I did the change, reassembled, and a couple minutes after opening the fuel valve I had fuel running down the sides of the bowl. Pulled the bowl back off, checked that the oring seal was still in place, and reassembled. This time I worked the bowl back and forth a couple times and all seemed well, but it now looks like I still have a seep.
This is such a simple mod I just don't get how it could leak??? Guessing maybe I need to push out the floor of the bowl just a bit to get a more snug fit on the upper rim against the seal? Everything sure looked clean and dry when I put the bowl back on. Hoping maybe someone else had an experience like this and could shed some light.
TD-Max is online now
post #2 of 25 Unread 01-24-2020, 01:44 PM
2muchsnow's Avatar
Likes (Given): 12
Likes (Received): 20
Originally Posted by TD-Max View Post
Brand new machine I did the change reassembled and a couple minutes after opening the fuel valve I had fuel running down the sides of the bowl. Pulled the bowl, checked that the oring seal was still in place and reassembled. This time I worked the bowl back and forth a couple times. All seemed well, but looks like I still have a seep.
There's actually a whole thread (or several) on this somewhere, but you have to make sure the carb bowl is in the exact position it was before or the float will get hung up and it will leak. I want to say it the drain valve should be about 30 degrees off from center. I'll see if I can find the thread.
2muchsnow is online now
Thanks TD-Max thanked for this post
post #3 of 25 Unread 01-24-2020, 01:46 PM
2muchsnow's Avatar
Likes (Given): 12
That was quick...here you go. See post 5.
https://www.snowblowerforum.com/foru...leak-help.html
post #4 of 25 Unread 01-24-2020, 01:55 PM Thread Starter
Thanks, I'll check it out. Almost undoubtedly my issue I'd say. The fuel level shouldn't be at the seam normally so i'm sure this is my issue.
Haven't been overly impressed with the TQ so far on this machine, but I guess if the float level is riding high it could be running rich.
post #5 of 25 Unread 01-24-2020, 05:10 PM
orangputeh's Avatar
Thanks (Given): 745
Thanks (Received): 219
Likes (Given): 1476
Likes (Received): 1463
see this problem all the time. either O ring is not is slot right or the bowl is on out of position. hanging up float so overfilling. you can look at inside of bowl to see how the float should match up. when you get it right get a scribe and mark outside of bowl and carb for future reference. or paint as most shops use.
a sharpy marker will just wash off with the gas.
"It Feels Like Beer O'Clock "
orangputeh is online now
post #6 of 25 Unread 01-24-2020, 08:36 PM
Thanks (Received): 14
Likes (Received): 19
I wish I could believe this theory because it could alleviate many leaking Honda float bowls symptoms - - - but I just cant! What part is hanging up on what part and how does rotating the float bowl relieve the symptoms? Keep in mind the float is being held down somehow????
cpchriste is online now
post #7 of 25 Unread 01-24-2020, 08:42 PM
WVguy's Avatar
Thanks (Received): 42
Likes (Received): 164
The float bowl is asymmetric, meaning it is not the same all the way around. If it is not positioned properly so that the deepest part of the bowl is underneath where the float is, the float will be pushed up so that it cannot drop down and fuel will continue to flow even when the bowl is full.
The only thing holding the float down is gravity. Generally that's pretty reliable, but if something is holding the float up then even gravity won't hold it down.
WVguy is offline
post #8 of 25 Unread 01-24-2020, 08:46 PM
When the float is pushed up then fuel flow will be cut off. I've never seen a float bowl that isn't very symmetric, from Honda or from anyone. That said, I'd love to be convinced.
post #9 of 25 Unread 01-24-2020, 09:16 PM
WVguy's Avatar
Well, I'm not gonna get out my DSLR, put on a macro lens and set up the macro flash to photograph the float bowl on my Honda generator, then edit the image in Lightroom, export to a .jpg file and upload it here just to prove SGOTI is wrong, so I'll just refer you various and sundry videos on youtube. And no, I'm not gonna do your homework for you and look it up.
WVguy is offline
post #10 of 25 Unread 01-24-2020, 09:28 PM
2muchsnow's Avatar
Likes (Given): 12
Is this close enough? Based on the picture it's supposed to go a certain way to allow the float to move without being pinched and stuck either open or closed.
To cold out for a full disassembly.Carb leak after jetting change-img_20200124_201927.jpg
Sent from my Pixel 4 XL using Tapatalk
