Honda height adjust lock - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 03-19-2020, 03:20 PM Thread Starter
Hi, l have a tracked hydrostatic Honda 928 here in Canada. The height adjust damper will not stay locked. It appears that the damper is okay but the locking device ( which l do not understand) fails to operate and the blower just rides high. Any one can give me advice. Thanks in advance.
Apilac is offline
post #2 of 11 Old 03-19-2020, 04:03 PM
Thanks (Given): 48
Thanks (Received): 248
Likes (Given): 144
Likes (Received): 500
Pour some boiling water over the piston, plunger and the locking mechanism. Ice can form in there and keep the locking mechanism from functioning. There's a rod inside the plunger that sticks out and is actuated by the lever mechanism to lock and unlock the piston.
tabora is offline
post #3 of 11 Old 03-19-2020, 09:49 PM
Thanks (Given): 31
Thanks (Received): 22
Likes (Given): 192
Post your location in Canada, maybe someone on here is near by...
contender is online now
post #4 of 11 Old 03-19-2020, 10:56 PM
Likes (Received): 14
If all else fails a new damper (shock) can be had at the dealer for around $50.
Fortech1977 is offline
post #5 of 11 Old 03-20-2020, 09:08 AM
orangputeh's Avatar
Thanks (Given): 763
Thanks (Received): 236
Likes (Given): 1584
Likes (Received): 1678
is this another common problem with these Honda's?
"It Feels Like Beer O'Clock "
orangputeh is online now
post #6 of 11 Old 03-20-2020, 12:05 PM
Thanks (Received): 20
Likes (Received): 55
I converted my HS 1128 to the HSS style height adjuster. My local dealer told me that he hasn't had any failures of the height adjuster struts other than people running them into something and bending them. It sounds like you have a problem with the cable that actuates the release, maybe a broken cable or just not adjusted correctly. The cable pulls on an arm that pushes on a nub that sticks out of the end of the rod end of the strut.
thefixer is online now
post #7 of 11 Old 03-20-2020, 12:20 PM
orangputeh's Avatar
Thanks (Given): 763
Likes (Given): 1584
hey buddy how ya doing?
busy? this last storm has me swamped. haha
post #8 of 11 Old 03-20-2020, 03:43 PM
Thanks (Given): 48
Likes (Given): 144
Not too common; only the third occurrence I've heard of and usually easy to remedy as mentioned above.
Also see here: https://www.snowblowerforum.com/foru...-problems.html
tabora is offline
post #9 of 11 Old 03-23-2020, 06:57 PM
Mine failed last year and needed replacement on my 2013 HSS724. The “nub” that allows the damper to bypass was broken.
post #10 of 11 Old 03-25-2020, 05:43 AM
Thanks (Received): 28
Likes (Given): 142
Likes (Received): 57
Throwing out the welcome mat for your first post...Hearty welcome from Penciltucky!
2019 Ariens Compact 24...
penna stogey is offline
