Auger handle adjustment - Page 2 - Snowblower Forum : Snow Blower Forums
post #11 of 12 Old 01-29-2016, 04:36 PM
Thanks (Received): 21
Likes (Received): 27
My 624 auger does not generally return fully most the time, it goes about half way. The return springs look a little corroded, and they don't feel like they have as much tension as the ones on my 828. I had the thing tore apart and everything looked fine, so I assume it's a worn return spring. A very simple repair, and it's probably a good idea to make it work properly. If the spring is missing or broken it would do the same thing. The spring is important since it pulls a brake onto the belt so the impeller stops. Otherwise it spins down on its own accord, and this can take a while if its unloaded. I got in the habit of pulling the handle up, since I don't let off the auger much anyways. But replacing that spring is on my to do list.
And for the handles not latching, one of mine wasn't latching when I got it. I dumped some oil on all the suspicious moving bits and it works great now. The one that was working was a little less 'positive' than the newly lubricated one, so I did that one too and they both snap in nicely now.
ZOMGVTEK is offline
post #12 of 12 Old 01-29-2016, 04:50 PM
jrom's Avatar
Thanks (Given): 346
Thanks (Received): 107
Likes (Given): 1063
Likes (Received): 188
From my experience, if I had to get into the engage and return springs area by the belts, I'd replace all four springs ($16.70 + shipping).
I had a drive clutch return spring snap a few years ago and it shredded the drive belt. I ended up replacing all four since it was cheap enough at the time.
The only bummer I encountered was no one had the one spring I needed in stock. It took 2 months to get it. I now have an extra new one and I kept the old ones I took off.
Spares can be King at my house.
Honda HS828TAS (1991) Made in Japan with Thai built GX240
Honda HSS1332ATD (Late-2015) Made in USA with Thai built GX390
180" to a rare 350" of snow per year (Alberta Clippers & Lake Michigan), 644' gravel driveway, 2 vehicle parking areas, 500' of trails around small house with an unheated garage.
jrom is online now
