Husqvarna ST227P Impeller Pulley Removal? - Page 4 - Snowblower Forum : Snow Blower Forums
post #31 of 45 Old 02-05-2019, 03:25 PM
Joined the bent impeller party on my 227P, a rock got in there good, nothing sheared, but it bent one of the tines enough that it became a rapid fire bolt remover. Parts are on order from a place down in Miami (where it never snows, go figure). I'd already ordered a few parts but didn't realize how bad the impeller was bent until I dug into it today so I had to go back for more. At least the replacement parts are inexpensive.
Main problem I have is that I clear part of my (dirt) road with it and never adjusted the feet, so occasionally it'll pull in a rock and the rest is history. Once I get it back together I'll be adjusting those things and hopefully will avoid a repeat!
unholy79 is offline
post #32 of 45 Old 02-07-2019, 01:40 AM
Originally Posted by sameproblem View Post
the nut is actually welded to the pulley, and they use a red loctite on it. so when you try to remove the pulley it is almost impossible to remove by hand,i took mine to a john dealer had them remove with an impact gun! Then i i heated the loctite inside of the nut, when still warm i used a steel bore brush and got all the loctite residue out of the nut before i put it back on. Do this so you do not ruin the threads when putting it back on!
I also have a bent impeller. I have been working on getting the pulley off for hours now. The pipe wrench on the shaft keeps that from spinning but I'm afraid to use any more force than I have been. I have tried heating the pulley nut with a torch but it looks like soft alu and I haven't gone red hot. Am I just being too gentle? I'm getting pissed. (angry not drunk)
steatopygia is offline
post #33 of 45 Old 02-20-2019, 10:24 PM
Just swapped the impeller out today, hardest part was getting that pulley off. In my case, I jammed a small 1x4 into the impeller through the chute opening, wedging it nicely, and then used a 1/2" drive 15/16's socket on a breaker bar to fight it off. It took a LOT more force than I expected, but then after removing I saw all the red threadlocker they used. Eventually it turned easier and came off.
As for getting the shaft out of the machine, I removed the bearing retainers on either side of the auger housing, unbolted the auger from the bearing so that the augers were floating in the housing. I placed it open-side down, put that 1x4 on the rear of the shaft and gave it a good whack with a hand sledge. Popped right out.
Someone else here posted about a small ridge that keeps the impeller from being able to slide right off, they were right. I used a small file to even it out and slip it off.
I also put the entire machine in my living room because my garage isn't heated. Helped greatly.
unholy79 is offline
post #34 of 45 Old 02-20-2019, 10:28 PM
WVguy's Avatar
Thanks (Received): 42
Likes (Received): 166
Lemme take a wild guess here. There are no females living there, right?
WVguy is offline
post #35 of 45 Old 02-21-2019, 04:07 PM
Nope, last one had an issue with me rebuilding a 550cc motorcycle engine in the kitchen.
unholy79 is offline
post #36 of 45 Old 02-21-2019, 05:09 PM
Thanks (Given): 145
Thanks (Received): 322
Likes (Given): 429
Likes (Received): 769
Sigh. And out of that picture, what caught my eye was the Nintendo zapper light gun, presumably nicely paired up with a CRT TV, so it can actually work Cool!
I wish modern consoles could still work with a light gun, that's a game genre that's sort of disappeared. Maybe the VR systems will make that kinda happen somehow.
post #37 of 45 Old 02-21-2019, 09:28 PM
Yup, and I always keep a spare CRT on hand in case that one dies. SNES to the left and my Genesis is behind it. Even if I could play Duck Hunt in VR, it wouldn't be the same.
unholy79 is offline
post #38 of 45 Old 02-21-2019, 09:38 PM
WVguy's Avatar
Yeah, females are like that. For a while there I did have a Yamaha XS650 stored over the winter in my living room. But I was single then, now my wife complains about R/C model airplanes in the dining room.
WVguy is offline
post #39 of 45 Old 01-06-2020, 03:33 PM
How about why is the impeller bending? My ST224 second time bending the impeller, when it happens the engine is stalled out. Where is the protection from the shear pins. If there is enough force to stall the engine and bend the impeller fins I think the pins should shear. Cost me $300 last year at the shop. Called Husqvarna maybe a warranty issue.
Duker is offline
post #40 of 45 Old 01-08-2020, 09:57 PM
Same problem.This is good. But for my ST230P, I just stuck a wonder bar between the impeller blade and the chute housing. The nut and the pulley wheel are fused. They don't separate like the parts diagram implies. However, I'm unable to get the impeller off of the shaft - The gear box, even after disassembling it, prevents on the one end. And, a flared edge/lip on the end where it goes into the bearing prevents sliding off of that end. Seems like the gearing needs to slide off the shaft (as that end appears tapered)? Has anyone been into this situation? Seems like a terrible design.
https://photos.google.com/photo/AF1Q...Pe0z0aoZiAWm9g
https://photos.google.com/photo/AF1Q...2KtsdjFfXJsf3I
https://photos.google.com/photo/AF1Q...LJu-7qMKbY2gRY
SnowMN is offline
