husqvarna with Berco snow blower plugged - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 01-28-2018, 10:02 PM Thread Starter
Does anyone have a way to prevent a plugged blower when in wet snow? Can the blower be sprayed or treated with something that is non-sticking to the blower?
Thanks!
Steve Sowle is offline
post #2 of 5 Old 01-28-2018, 10:13 PM
Thanks (Received): 100
Likes (Given): 101
Likes (Received): 242
There ARE sprays but none will last all that long, Best bet would to do a impeller mod, Basically adding rubber wipers to the impeller and it stops clogging, Do a search on impeller mod on youtube and they will show you how to add it and what to use to make the wipers, They also sell kits on ebay for it also.
Dauntae is offline
post #3 of 5 Old 01-28-2018, 10:22 PM
SAVAGE420's Avatar
Thanks (Given): 67
Thanks (Received): 20
Likes (Received): 80
Manually rub snowboard wax on everything you don't want snow to stick. It lasts a long time.
Sprays last 10 minutes if that, garbage and waist of time and money.
Next best thing is to line the shoot/housing worth plastic ect
Sent from my Shed!
Doin things n stuff.
_________________________
2017 Husqvarna ST330P
1998 Craftsman 10/28 tracked
1980 Toro 11/32
SAVAGE420 is offline
post #4 of 5 Old 01-28-2018, 10:41 PM
Thanks (Given): 509
Thanks (Received): 679
Likes (Given): 3830
Likes (Received): 1472
to SBF Steve
Impeller kit is the way to go. It's more work than a spray or wax but once you do it, it's done and the results are never disappointing.
https://www.google.com/search?q=yout...hrome&ie=UTF-8
post #5 of 5 Old 01-29-2018, 05:22 AM
Guest
Thanks (Given): 20
Thanks (Received): 53
Likes (Given): 40
Likes (Received): 94
wet snow is wet snow,it will plug up anything when a machine is pushed to hard and fast though it. main reason i have blowers and blades on lawn tractors.
if a blower plugs up switch to a machine with a blade
10953 is offline
Likes ZTMAN liked this post
