300 Series Cable Routing - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 10-14-2018, 04:24 AM Thread Starter
SnowH8ter's Avatar
Likes (Given): 26
Likes (Received): 54
No snow! And the forecast indicates that we're in for a little summer-like reprieve. Drat! Oh, well, a little summer in the fall is not such a bad thing. So... while eagerly awaiting that snow, which is normally to my disdain, I've been pouring over this new machine (ST330P) with the proverbial fine-tooth comb. And while I did purchase the beast from a reputable dealer, I'm somewhat concerned about the way some of the cables etc have been routed. Some of it appears to be outside the influence of the dealer because the upper handles are simply folded over for shipping - cable routing would have been accomplished during manufacture. Started nitpicking with this issue when I noticed that the left turn trigger cable was up firmly against the recoil starter housing. Further probing revealed that the cable makes a rather tight downward exit out of the trigger and is firmly pressed up against the threaded end of a fastener. The right trigger is better in that regard but the cable is much too intimate with the auger control rod. Further to that, the wiring for the headlight, as it travels down, was again far too intimate with the auger control rod. I'm gonna fix all this stuff but it begs the question for other 300 Series Husky owners. Is it just this machine or am I watching the weather channel too much?
Wounded 30-inch Mastercraft (MTD) circa 96
17 ST330P Husky
SnowH8ter is offline
Likes SAVAGE420 liked this post
post #2 of 12 Old 10-14-2018, 04:39 AM
SAVAGE420's Avatar
Thanks (Given): 68
Likes (Given): 136
Likes (Received): 90
I'll snap a few pics of mine tomorrow if you want to see.
Sent from my SM-G950W using Tapatalk
Doin things n stuff.
_________________________
2017 Husqvarna ST330P
1998 Craftsman 10/28 tracked
1980 Toro 11/32
SAVAGE420 is offline
post #3 of 12 Old 10-14-2018, 04:51 AM Thread Starter
SnowH8ter's Avatar
Likes (Given): 26
I'm particularly interested in the freedom of movement of your auger control rod and drive control rod - these rods should not have anything rubbing against them. Many thx!
17 ST330P Husky
post #4 of 12 Old 10-14-2018, 12:50 PM
SAVAGE420's Avatar
Thanks (Given): 68
Likes (Given): 136
Let me know if you need a different angle or what not.
Now that you refreshed my memory, I moved both the steering trigger cables after I got it. Too where I thought it was better on the outside of the handle bars, 5 minute kind of deal. No problems at all. Then I zip tied all the cables so they didn't end up rubbing through anywhere or bind.
1980 Toro 11/32
Thanks SnowH8ter thanked for this post
Likes SnowH8ter liked this post
post #5 of 12 Old 10-14-2018, 04:00 PM Thread Starter
SnowH8ter's Avatar
Likes (Given): 26
Perfect! Thanks for the shots. Issues you've highlighted are precisely what I'm dealing with on this beast. Another project for tomorrow!
Cheers!
17 ST330P Husky
Thanks SAVAGE420 thanked for this post
post #6 of 12 Old 10-15-2018, 08:29 PM
Thanks (Received): 33
Lat8 to this thread. I cannot recall mine. it's all dusty right now.....but I do recall just moving things logically and I went to town with black zip ties.
mobiledynamics is offline
post #7 of 12 Old 10-19-2018, 12:28 AM Thread Starter
SnowH8ter's Avatar
Likes (Given): 26
Yep, that's about what the exercise boiled down to. My biggest concerns were with the left turn cable and the wiring from the heated grip switch. The left turn cable was positioned hard down coming out of the trigger and was up tight against the threaded ends of the left side fasteners that secure the control panel sub-assy to the handle bars. The wiring was routed in such a way as to be interfering with the auger interlock. All good now.
ID:	147439   Click image for larger version
17 ST330P Husky
post #8 of 12 Old 10-19-2018, 12:39 AM
SAVAGE420's Avatar
Thanks (Given): 68
Likes (Given): 136
Looks like you're all set.
Any snow your way yet?
1980 Toro 11/32
post #9 of 12 Old 10-19-2018, 12:56 AM Thread Starter
SnowH8ter's Avatar
Likes (Given): 26
LOL! It was 21 yesterday and 16 today. Supposed to be mild for the next week or so. Just need to be patient because I know it's that time of year when old man winter can come barging in with little or no notice.
17 ST330P Husky
post #10 of 12 Old 10-19-2018, 01:13 AM
SAVAGE420's Avatar
Thanks (Given): 68
Likes (Given): 136
What part of the country are you in again?
It's definitely been warm.
It dumped 40cm over night up at work a couple weeks ago. But it's warmed up and pretty much all gone now.
1980 Toro 11/32
