ST 224 - intake valve issue? - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 11-25-2018, 08:26 PM Thread Starter
Hi All,
I've searched but not found any info on the issue I'm having: ST 224 is virtually brand new (client dropped it off because it wouldn't run and now I know why) and there is NO compression. I thought the valves needed lapping, so I took the head off and cleaned them to almost new condition. Reinstalled, torqued everything down, and still no compression. I was thinking that the rings were shot, but, wanted to test further.
Then I plugged in starter and hit the button. Barely any pressure registered in the compression tester, but, ...misty gas was flying out the carb! (Also could feel air flow out of muffler). I'm assuming the intake valve is staying open; (right?).
Spring not good that should be closing intake valve? They're not the strongest looking things anyhow. Again, this machine looks brand new - no scratches on intake chute.
Any thoughts greatly appreciated. Thank you,
Jay
jaytpilk is offline
post #2 of 14 Old 11-25-2018, 09:24 PM
Grunt's Avatar
Thanks (Given): 236
Thanks (Received): 274
Likes (Given): 2767
Likes (Received): 500
Welcome to SBF Jay. This is an OHV engine, did you adjust both valves for clearance? I'm not sure what motor it is, but I would "think" .005 to .007 valve clearance would work. Air coming out the carb and muffler indicate BOTH valves are open. I assume the piston is moving up and down?
Toro 421-QZE (38585) 2008
Thanks jaytpilk thanked for this post
post #3 of 14 Old 11-26-2018, 02:48 AM
Thanks (Given): 7
Thanks (Received): 31
Likes (Given): 411
Likes (Received): 115
it's a 208 cc lct ohv engine shop manual states .005 to .007 intake , 007 to .009 exhaust valve clearance . that's where i would also start checking the valve setting
the op by inputting the engine model number can get a shop manual copy from here Service - Liquid Combustion Technology, LLC
132619 is offline
post #4 of 14 Old 11-26-2018, 11:11 AM Thread Starter
Thank you Grunt. To clarify, air was coming out of the carb and exhaust but not on the same stroke (I don't believe). I was just confirming that both valves were opening and flow was coming out of each, individually. Yes, the piston is moving up and down.
When I had the head off, the cylinder walls and piston looked to be in fine condition.
Please forgive my ignorance here, (I've done TONS of work on my cars, trucks, snowmobiles, chainsaws, and snowblowers - but...), how do I check that valve clearance? Pull the head and push down on the rocker and then measure the gap/opening of the valve "head" from the ..."seat"?
Thank you,
Jay
jaytpilk is offline
post #5 of 14 Old 11-26-2018, 11:19 AM Thread Starter
Thank you,
Jay
Disregard. I just found a great video showing me what to do.
Other question: When I took the valve cover off the first time, to check head gasket, I was not 100% careful to make sure that the "cap" atop the valve stem(s) didn't fly free. I noticed, when on the bench, that only the exhaust valve stem had this little cap on top, where the rocker presses against the top of the valve stem. I'll try and download the manual for my engine to see if BOTH should have this little cap. Wondering if that could be part of my issue...
jaytpilk is offline
post #6 of 14 Old 11-26-2018, 11:31 AM
Thanks (Given): 7
Likes (Given): 411
looking at the shop manual the secondary keeper as it is called is only on the exhaust valve
132619 is offline
post #7 of 14 Old 11-26-2018, 12:59 PM Thread Starter
Ah HAH. Well I definitely have the secondary keeper on the INTAKE valve, so that's problem #1. Thank you!!
But, interesting, when I follow the instructions of this video (assuming they're correct) I have no "play" between rocker arm and top of valves when piston is at TDC on compression stroke:
- Maybe that's why this engine wont run and has no compression...
:-). It's like a puzzle, putting everything together correctly. Going to try and follow the video and make sure the valve gap/lash is properly set, with that secondary keeper on the proper valve.
jaytpilk is offline
post #8 of 14 Old 11-26-2018, 01:11 PM Thread Starter
Hi Woodie. I got my engine number and input it on the Liquid Combustion site and got "a" manual, but, when I searched through it I did not find the valve gap info mentioned. Is there another manual I should get - a service manual? This looks more like an owners manual.
jaytpilk is offline
post #9 of 14 Old 11-26-2018, 01:14 PM Thread Starter
Ah... Once again, I should have tried more things before posting. I did get a Service Manual - it was a different option on the LCT site. Back to work
jaytpilk is offline
post #10 of 14 Old 11-26-2018, 01:34 PM Thread Starter
I did search the entire service manual and did not find what the compression PSI should be; do you folks know? 125? 150? Again, as Woodie notes, it's the 208cc engine.
Thank you !!!
Jay
jaytpilk is offline
