Tire Chains - Page 2 - Snowblower Forum : Snow Blower Forums
post #11 of 11 Old 01-23-2019, 07:02 AM
Homesteader's Avatar
Likes (Received): 33
I use chains because I grew up using chains on all my father’s and grandfather’s equipment. It makes a difference because not every storm will be light fluffy snow and easy to handle. I prefer preparing to a reasonable level for the worst of situations.
If you have turf tires, then 4 link chains will give you a bumpy ride and 2 link chains will be a bit smother.
If you have snow hog or x track tires then 4 link is acceptable but you must make sure the chain is large enough to protrude past the lug design of either tire. 2 link again is smoother but more expensive.
Also consider using tire chain tensioners or adjusters so you can use a lower tire psi and keep the chains in place under heavy use.
There are other options including v-bar but those will cause more damage on the long run.
https://www.tirechain.com/16x6.50x8.htm
Ariens ST1032 924084 (ST1232)
MODS: Tecumseh OHSK120 12hp, 3" Pulley, 6 Blade Impeller Kit, Hand Warmers w/ on-off switch, 1700 Lumen LED bulb,Front Weight Bar 18.5lbs, Chute Clean Out Tool, Tire Chains, Drift Cutters, Armorskids
Homesteader is offline
