ST224P Auger won’t disengage - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 02-01-2019, 02:13 PM Thread Starter
Cfrean@gmail.com's Avatar
Question ST224P Auger won’t disengage
Hi folks - I have a new ST224P. It worked fine for first storm, but since then, as soon as I first engage the auger, the auger doesn’t disengage when I release the trigger handle. After I shut down the engine and it sits in my garage, the trigger handle operates fine. I have opened the black housing and can see the return spring is working fine when I press the trigger handle. I suspect the cable may need adjustment or replacement (so soon?)... if I need to adjust the turnbuckle on the cable, any hints as to which way? Could a new cable be getting stuck? Thanks!
post #2 of 5 Old 02-01-2019, 08:16 PM
e.fisher26's Avatar
Thanks (Received): 40
Likes (Given): 29
Likes (Received): 50
I know this is obvious but this not happening when the drive handle is down correct? The auger handle will not release when the drive is engaged. If not then check the little black plastic right under the auger handle with teeth on it, some times they can catch.
Noma 10/29
Cub cadet 5/26 conv to 8/26
Toro 8/24
Husqvarna st230p
e.fisher26 is online now
post #3 of 5 Old 02-02-2019, 10:30 AM Thread Starter
Noma 10/29
Toro 8/24
Husqvarna st230p
Thanks, Noma — I’ll check that interlock. That could be the problem. Will report back!
post #4 of 5 Old 02-02-2019, 11:29 AM
If the lever is in the up position and the auger is still running, your auger cable may need adjustment to put more slack in it, allowing the brake to engage.
kenmand is offline
post #5 of 5 Old 02-04-2019, 03:44 PM Thread Starter
Thanks for this — I took it out yesterday and of course everything worked just fine🙄, so I was unable to confirm whether the interlock was sticking or not. Good to know that I may need to slacken the cable if the problem returns when Drive is not engaged.
