Help Finding Part (Carburetor) for Husqvarna 10530SBE - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 09-22-2016, 10:15 AM Thread Starter
I have an older Husqvarna 10530SBE and it has a leaky carburetor. I've looked on some parts sites and can't seem to determine which of the repair kits (or replacement carbs) is the right one. Per the plaque here is all the info I have on my snow blower:
Husqvarna 10530SBE
Product# Maint. Level
961950001 01
Serial Number
101805M 004205
One site has these options - again no idea which of these, if any, is right for me. I'm also not sure if the repair kits are worth the time, or if I should just get the whole carb and swap it out:
121 497535 ! KIT-CARB OVERHAUL | (LMT 92, 93, 94, 95, 96, 108, 111, 162, 165, 169) $44.95
1
121 499231 KIT-CARB OVERHAUL | (LMT 97, 99, 133, 135, 136, 157, 158, 159, 160, 166, 168) $100.60
1
121 697884 KIT-CARB OVERHAUL | (696160, 696162, 696164, 696166, 697212, 697213, 697214, 697906) $56.75
1
121 497481 KIT-CARB OVERHAUL | (LMT 63, 65, 66) $38.20
1
125 698171 CARBURETOR | (696160, 696162, 696164, 696166, 697212, 697213, 697214, 697906) $151.10
1
125 799728 ! CARBURETOR | (LMT 37, 77, 78, 79, 80, 81, 92, 93, 94, 96, 97, 99, 100, 108, 109,110, 111, 133, 134, 135, 136, 157, 158, 162, 165)(Gravity Feed) $149.55
1
125 499158 CARBURETOR | (LMT 159, 166, 167, 168, 169)(Pump Feed) $106.40
Any advice or help finding the right part is appreciated!
Ron_C is offline
post #2 of 8 Old 09-22-2016, 12:16 PM
Jackmels's Avatar
Thanks (Given): 98
Likes (Given): 313
Likes (Received): 621
Look for an aftermarket carb on ebay. GL.
Jackmels is online now
post #3 of 8 Old 09-22-2016, 01:59 PM
stromr's Avatar
Thanks (Received): 38
Likes (Received): 63
Smile
I'd say you need the numbers off the engine, I'm guessing here but it's probably a Tecumseh engine with a number something like this: lh358sa-159628a
stromr is offline
post #4 of 8 Old 09-22-2016, 03:28 PM
Thanks (Given): 510
Thanks (Received): 681
Likes (Given): 3844
Likes (Received): 1478
You need the numbers off the engine itself.
post #5 of 8 Old 09-22-2016, 04:00 PM
Likes (Received): 302
What's leaking? While it runs, or left in storage? Was it left with the fuel on? Pics would really speed up the diagnosis.
Engine numbers may be stamped into the recoil shrouding assembly if it's a Tec.. If you can post a pic of the engine, we can quickly tell you what you're dealing with. Tecumseh stamped numbers along the top of the recoil assembly shrouding, sometimes hidden half way by the electric start plug assembly.
post #6 of 8 Old 10-16-2016, 04:58 PM
This is what I got for my 2006 10530SBE (LH358SA-159628A)... Oregon 50-659 Carburetor Replacement for Tecumseh 640349.
Husqvarna_10530SBE is offline
post #7 of 8 Old 10-16-2016, 07:28 PM
stromr's Avatar
stromr is offline
post #8 of 8 Old 10-17-2016, 08:55 AM
Husqvarna 10530SBE
961950001 01
Serial Number
101805M 004205
1
1
1
1
1
1
Based off of your numbers, we have the same 10530SBE. Your carburetor should be the 640349. The Tecumseh replacement is over $100. The Oregon replacement that I posted above is a direct replacement that usually costs about $15-20. Mine has been working great. I tried a rebuild kit on the original carburetor, to have it as back up, but it didn't run much better.
If you have or know a good small engines shop nearby, you may be better off having them do the work. You supply the parts.
