Hi to my fellow Husqvarna Owners... - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 11-21-2016, 11:00 PM Thread Starter
Hi to my fellow Husqvarna Owners...OEM LED upgrade anyone?
Hi Guys,
I am new to the forum. I have been lurking here for a while and finally decided to get involved. I live in CT and own a 10530SBE. It seems like a pretty good machine these past couple of years.
I have some of the typical issues with it pulling to the right which I have to dig into. I have checked the tire pressures and skid heights but still pulls so I need to hunt around on the forum a bit more for help on that.
I was curious if anyone has anyone here tried to upgrade their current halogen beams with the OEM LED light kits? I saw the LED upgrade sticky here on the forum but I was curious if any tried this more OEM upgrade for the Husqvarna's yet? They are available on repairclinics site and for $26.00 it might be worth a try.
RepairClinic Item #3133400 | Husqvarna Genuine OEM Part #581684202
Update phase one completed and it works!
https://www.snowblowerforum.com/forum...=94202&thumb=1
Regards,
Manny
Name:	Single LED 2.jpg
mannyj is offline
post #2 of 15 Old 11-22-2016, 05:00 AM
Zavie's Avatar
Thanks (Given): 40
Thanks (Received): 72
Likes (Given): 280
Likes (Received): 146
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is online now
post #3 of 15 Old 11-26-2016, 05:52 AM
SAVAGE420's Avatar
Thanks (Given): 67
Thanks (Received): 20
Likes (Received): 80
Welcome aboard!!! Have you checked to see if the right steering trigger is sticking a bit?
Doin things n stuff.
_________________________
2017 Husqvarna ST330P
1998 Craftsman 10/28 tracked
1980 Toro 11/32
SAVAGE420 is offline
post #4 of 15 Old 11-27-2016, 09:45 AM Thread Starter
As a matter of fact the trigger does stick. What's the best fix in your opinion?
mannyj is offline
post #5 of 15 Old 11-27-2016, 12:06 PM
SAVAGE420's Avatar
Thanks (Given): 67
Good lil read and video.
http://movingsnow.com/2013/power-ste...ick-quick-fix/
Paul is awesome!
Sent from my shed!
1980 Toro 11/32
post #6 of 15 Old 11-27-2016, 12:30 PM Thread Starter
Thanks again. I watched that one last year and tried the graphite spray. No joy though. It almost seems like the cable could be binding up somewhere but when I trace the path I don't see anything.
mannyj is offline
post #7 of 15 Old 11-27-2016, 02:48 PM
Hanky's Avatar
Thanks (Given): 84
Thanks (Received): 69
Likes (Given): 298
Likes (Received): 133
My local dealer has a spray just for cables. Check with motor cycle shops they might have thing for cables.
Hanky is online now
post #8 of 15 Old 11-27-2016, 11:58 PM
SAVAGE420's Avatar
Thanks (Given): 67
Ya, what hanky said. I have a lube kit I use for the cables on my quad. It comes with spray lube and a spray clamp to get the lube in the cable simply without a mess.
It looks like this. Not very expensive at all. Think about $20ish.
Sent from my shed!
1980 Toro 11/32
Thanks nwcove, E350 thanked for this post
Likes Hanky liked this post
post #9 of 15 Old 11-28-2016, 04:16 PM Thread Starter
Thanks for the suggestion Sav. Looks like I'll be making a trip to AutoZone during lunch one day this week to see if they have one of those.
I stopped by my local Husqvarna dealership today to pick up an oil filter for my mower and to do some recon on my oem LED upgrade project. I want to swap out my halogen lamp for an LED unit from an ST327P or ST330P. I was curious to see if the LED units had some sort of built in rectifier to convert the AC to DC so that it could be just swapped out for my halogen. Good news is that I didn't see anything that resembled a rectifier outside of the lights housing so I may be in luck there (stay tuned for that little project).
While I was there I asked the tech about the sticking cables and he said he hasn't ever heard of this happening on the Husqvarna's which I thought was odd since it seems to happen with some frequency (at least from what I have found online).
mannyj is offline
post #10 of 15 Old 11-28-2016, 08:23 PM
Thanks (Received): 132
Likes (Given): 196
Likes (Received): 283
Is it the cable that is sticking, or the gadget that they used the dry lube on in the video?
I have one of those cable lubers to inject lubricant into the cable housing and it works really well. I've also done the baggie and rubber band trick and let gravity and time send some lubricant into the cable and housing.
Example
dbert is online now
