Look what found me today!! - Page 4 - Snowblower Forum : Snow Blower Forums
post #31 of 36 Old 01-26-2020, 08:49 PM Thread Starter
thefixer's Avatar
Thanks (Received): 20
Likes (Received): 51
In this picture you can see the chain tensioner in the wrong position. It is supposed to be flipped up with that flat pad sitting against the adjusting bolt.
thefixer is online now
post #32 of 36 Old 01-26-2020, 08:53 PM Thread Starter
thefixer's Avatar
This is how it is supposed to be.
Likes dbert liked this post
post #33 of 36 Old 02-11-2020, 09:36 PM Thread Starter
thefixer's Avatar
I've been messing around with this thing while waiting for my tracks. They are coming from China so I hope the Woo Flu doesn't mess up my shipping too bad. So I put a new impeller on it and what does every impeller want, a nice set of impeller flaps !! The clearances were probably on the short side of 3/16" but I think every snowblower should have impeller flaps. I also converted my chute rotate from a manual crank, to an electric control since this blower has a real 12 volt dc electrical system. I want to make sure this has all the goodies before I sell it to Mark !!
ID:	163829   Click image for larger version
ID:	163831   Click image for larger version
ID:	163833   Click image for larger version
post #34 of 36 Old 02-12-2020, 11:55 PM
Likes (Given): 213
Likes (Received): 304
That is awesome. How long will it take to go from stop to stop?
Made me laugh.
dbert is offline
post #35 of 36 Old 02-13-2020, 01:12 AM Thread Starter
thefixer's Avatar
I think about 5 seconds. It's pretty fast. I'll try and post up a video.
post #36 of 36 Unread Today, 06:22 PM
leonz's Avatar
Thanks (Received): 90
Likes (Given): 76
Likes (Received): 177
All you need to do now is remove the two stage snow blower and replace it with an MK Martin 48 inch single stage and you will have a real drag racing machine as the single stage snow blower rotor on it can spin up to 700 RPM.
You would need to do a bit of machine shop work and some welding to make a winch mounting plate and then you can double or triple your tonnage per hour with simple sprocket changes.
It would not take much work to mount the three point hitch on the hydraulic lift of the snow blower and machine a small
PTO propeller shaft with universal joints and female yokes to match up with the drive end mount of the engine and the 540 RPM gearbox of the single stage snow blower.
leonz is offline
