Page 1 of 2 | 1 | 2 |
LinkBack | Thread Tools |
My father bought a John Deere 1032 at an auction that looks like an older machine but one that's barely been used. I'm going to pick it up this weekend but talking to him this morning he mentioned he didn't see an air filter on the engine nor a place one would go on the carb.
My question is, is this normal for an older John Deere 1032 snow blower to not have an air filter and two does anyone have a user manual?
Thank you for your time!
Sponsored Links | |||
Advertisement |
Snowblowers typically don't have air filters.
Here is a manual...
https://www.dropbox.com/s/3jh4tugqqp...r%20Manual.pdf
Here is a manual...
Post Thanks / Like - 0 Thanks, 2 Likes, 0 Dislikes |
I was looking for the same exact thing when researching/shopping for a new machine and found out exactly what russkat stated. Snowblowers don't have air filters because they're apparently not needed in the environment that they're utilized in - very little, if any, dust & dirt.
And I guess if you think about it, an air filter on a snowblower could potentially be a place for snow/water/ice to collect and build up, clogging your air flow.
"It's better to have it and not need it than to need it and not have it."
2018 Ariens Platinum SHO Track 28
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes |
Originally Posted by russkat
View Post
Here is a manual...
Here is a manual...
Originally Posted by Paulie139
View Post
Originally Posted by blowinsnow
View Post
Paulie I didn't even think about an air filter being a place to clog up from snow and ice but that makes perfectly good sense. Today I learned!
87 powershift is though - maybe he can tell us if that's a plausible theory.
87 powershift: input, please?
yes there is no air filter, snow won't hurt as the motor uses a heater box and hot air from the cooling fins of the motor to close to superheat around the carb and to preheat the air thereby melting anything before it gets into the carb or motor.
if the motor was on a lawn mower yes they are needed big time, to much dirt and dust from the grass clippings something snow dosen't have.
Originally Posted by 87 powershift
View Post
They clean up and paint up nicely. What condition is the scraper bar and skid shoes in? Give her an oil change. 5W30 and maybe add a bit of ZDP additive as well. New Champion spark plug will be good as well or some suggest NGK spark plug. I've never encountered an issue with the Champion plugs and that is what most repair shops use as well. Check the condition of the fuel line that runs from the tank into the carb as well. Rotted? Primer line rotted? Pull the gear case cover off and have a look inside. Grease her up.
been having a lot of issues with resistor champs fouling a lot lately. even brand new .
Advertisement |
Previous Thread
Next Thread
Thread Tools | |
Posting Rules | |
