1130se parts - Snowblower Forum : Snow Blower Forums
post #1 of 61 Old 12-29-2017, 05:50 PM Thread Starter
Money_man's Avatar
1130se parts
I have a 2009 model 1130se and I'm curious where you guys get your parts. Also what other makes of snowblower fit the JD? If I know that I'll have an easier time tracking down parts that aren't from the John Deere dealer only. I currently have possibly slightly bent auger and if I watch the auger pulley I can see the shaft has to be bent because the pulley is wobbling. Previous owner got frustrated and somehow chewed the clearing blade off on one side and slightly into the housing.
Money_man is offline
post #2 of 61 Old 12-29-2017, 06:38 PM
Thanks (Given): 96
Likes (Given): 75
Likes (Received): 458
I believe that's a Murray made machine so look for that, same as a Craftsman.
post #3 of 61 Old 12-31-2017, 09:18 PM Thread Starter
Money_man's Avatar
Some pics I got. Not sure how to tell what Murray models would work.
ID:	122025   Click image for larger version
post #4 of 61 Old 12-31-2017, 09:24 PM
Thanks (Given): 96
Likes (Given): 75
Most if not all.
post #5 of 61 Old 12-31-2017, 09:51 PM
Likes (Received): 303
125
post #6 of 61 Old 12-31-2017, 09:52 PM Thread Starter
Money_man's Avatar
Yessir. I can get a better picture tomorrow.
post #7 of 61 Old 01-01-2018, 09:26 AM Thread Starter
Money_man's Avatar
So is this correct and the shaft from the pulley to the gearcase is not replaceable? Going to get outside in about an hour to take a better look at this. Need to move it from the shed to the garage anyway.
post #8 of 61 Old 01-01-2018, 09:38 AM Thread Starter
Money_man's Avatar
I do know the auger bearings are new with about 10 hours on them. The gearcase was replaced just before I was given the unit. The left auger looking at the unit was supposedly slightly bent so they bent it back. I'll have more information when I get outside to look at stuff.
post #9 of 61 Old 01-01-2018, 10:18 AM Thread Starter
Money_man's Avatar
Ok just got some pictures. Found a couple things that seem off to me. First its obvious I'm missing a bolt from the gearcase to the housing support (pic #3) so that's probably a bit of my rattle I've been looking for. Then I noticed the shaft coming out of the gearcase doesn't seem to be straight with the gearcase (pic 4). The bearing holder (pic 5) seems to be cracked next to one of the bolts.
Augers spin freely on their shafts so they aren't seized. The impeller looks perfect as well, looked for bends and cracks. I can run out and look at anything you need me to. Need to get it in the garage when the baby gets up because hard to do anything in -20c.
ID:	122113   Click image for larger version
ID:	122121   Click image for larger version
ID:	122129   Click image for larger version
ID:	122137   Click image for larger version
post #10 of 61 Old 01-01-2018, 01:52 PM Thread Starter
Money_man's Avatar
Ok. So how do I post a video? I don't know what's wrong but it's not great.
