John deere 828D - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 01-16-2018, 09:13 PM Thread Starter
John deere 828D
Blown Tecumseh 8hp,medium skill level my son can weld,what Predator is the easiest to repower?This site is great but I'm new here and not familiar .Thanks for suggestions
Jerry Leonard is offline
post #2 of 16 Old 01-16-2018, 09:17 PM
predator may be slightly underpowered for a 28
post #3 of 16 Old 01-16-2018, 09:55 PM
GoBlowSnow's Avatar
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 268
I was afraid there would not be a predator engine for a 28inch machine
GoBlowSnow is offline
post #4 of 16 Old 01-16-2018, 10:01 PM
Thanks (Given): 96
Likes (Given): 75
Likes (Received): 460
Predator comes in different sizes. The one most discussed on here, 99.5% of the time is the 212cc, about 6 1/2hp but equivalent to an old 8hp Tecumseh flat head members have claimed. The Predator and all the Chinese engines are OHV, much more efficient and powerful.
Predators also come in two larger sizes, 300+cc and 400+cc. Using them you'll be able to use the old pulleys as the crank shaft size it's the same. The 212 Predator crank is smaller, 3/4" rather than 1" .
post #5 of 16 Old 01-17-2018, 09:35 AM Thread Starter
what motor
would work with the least amount of modifications? Thanks again
post #6 of 16 Old 01-17-2018, 09:41 AM Thread Starter
301cc
I have looked at this one,The 1" shaft is inches higher than the Tec& the bolt pattern is not close
post #7 of 16 Old 01-17-2018, 09:54 AM
Likes (Received): 303
651
post #8 of 16 Old 01-17-2018, 10:10 AM
Thanks (Given): 96
Likes (Given): 75
So? you buy longer belts to compensate, and you drill new holes.
post #9 of 16 Old 01-17-2018, 11:34 AM Thread Starter
CL
Originally Posted by jtclays View Post
Another 8hp Tecumseh
Not joking, it's the easiest swap. Craigs list search for "horizontal shaft" usually picks up a few listings. If you type in tecumseh, you'll get every mower and snowblower ad coming up. Often times you can find a rusted out complete blower with a running engine cheaper than a new engine. If yours is single output shaft you can use a dual shaft engine also if you find one. You can easily cut off the cam pto shaft so the belt guard fits.
Around me, I would look for a complete blower vs. engines. Typically with the engine off a machine are sold by flippers or people trying to make back money by parting a machine and as such are usually overpriced or inaccurately advertised as "hard to find, won't last long" type of thing.
I have been searching,I know on local small repair shop to check with Thanks
post #10 of 16 Old 01-17-2018, 12:42 PM
654654
