led lights for my JD x390 - Snowblower Forum : Snow Blower Forums
post #1 of 2 Old 03-16-2018, 10:46 AM Thread Starter
Im going to be hooking up tail lights/four ways and lights on my blower. my question i guess is do i need a rectifier or will it be a straight of the battery with a fuse/flasher and to a switch?
Lawdog138 is offline
post #2 of 2 Old 03-16-2018, 11:51 AM
drmerdp's Avatar
Thanks (Received): 149
Likes (Given): 24
Likes (Received): 308
Specs show a 15amp charging system so Iíd say itís robust enough to add a bunch of lights directly off the battery.
Headlights are spec-ed at a pair of 27w incandescent bulbs. Lots of head way for the addition of LEDs
I donít know how itís wired though. Are the headlights powered by a separate lighting coil, or ran off the battery with a relay.
You need to see if you have AC or DC power at the headlights.
drmerdp is offline
