Is it an '87 ?? M01032X - Snowblower Forum : Snow Blower Forums
Old 05-14-2018, 10:47 PM Thread Starter
Thanks (Given): 522
Thanks (Received): 690
Likes (Given): 3908
Likes (Received): 1501
Ran across this JD needing some work on Crigslist. The engine numbers are HM100 159120(l or 1) serial 6160D which I think is made on June, 10 ???6
The Model is an *M01032X and the serial number is missing. Any ideas ?? Because of the chute I'm guessing it's an '87 but anyone know.
It's not the TRS or a 1032D and it's not made in Wisconsin so Ariens is out. Pretty sure it's a JD Deere.
Name:	180514 JD 1032 as advertised.jpg
ID:	145009   Click image for larger version
Name:	180514 JD 1032 before restore sm.jpg
ID:	145017   Click image for larger version
Name:	181514 JD 1032 ID plate sm.jpg
Old 05-14-2018, 11:04 PM
Thanks (Received): 137
Likes (Given): 202
Likes (Received): 287
Looks like a John Deere built John Deere to me. Not a Murray or Ariens like you said.
dbert is offline
Thanks (Given): 91
Thanks (Received): 180
Likes (Given): 70
Likes (Received): 418
The engine is a 1986 from the 6 in 6160, 160 is the Day of the year.
I have a 1983, the earlier models as I have, have a shorter chute than yours. I just added additional length to my chute.
Is this one from your barn that's been sitting?
Try to get the auger gear box cap off to change the gear oil. I was thinking of separating the auger housing, removing the fill plug on the gear box, then turning the auger housing upside down to drain it.
I find pulling up on the drive lever to be tiring. I'd like to find another lever from a different blower and flip it around so I press down on it.
Old 05-14-2018, 11:05 PM
Likes (Given): 202
I know we are probably not supposed to talk about this, but I'll ask anyway. What happened to our resident JD expert? JTC being banned here and at MTF.
dbert is offline
Likes Grunt liked this post
Old 05-14-2018, 11:16 PM Thread Starter
Thanks (Given): 522
Likes (Given): 3908
I just posted in a thread he posted in a day or two ago on MTF. Was it just yesterday or today ??
Update : sorry wasn't paying enough attention. I was thinking MLF
