Electric Starter 1032 - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 12-06-2018, 09:48 PM Thread Starter
Thanks (Given): 80
Thanks (Received): 47
Likes (Given): 277
Likes (Received): 157
I have a JD 1032 with a Tecumseh HM100-159094J engine, serial number 4220D. This appears to be an Ariens built model and the JD serial number is M01032X526091. I'd like to add an electric starter but can't find the Tecumseh part number after a lot of Google searching. Every parts diagram shows the optional electrical starter but never references the actual part number.
I don't think this blower ever had an electric starter because the the flywheel cover plate is intact. The engine does have the necessary mounting holes.
Any help would be greatly appreciated and four photos are attached.
ID:	149653   Click image for larger version
ID:	149655   Click image for larger version
ID:	149657   Click image for larger version
rod330 is online now
post #2 of 14 Old 12-06-2018, 10:48 PM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
Tecumseh 33329
db130 is online now
Thanks rod330 thanked for this post
post #3 of 14 Old 12-07-2018, 12:39 AM
Thanks (Given): 591
Thanks (Received): 772
Likes (Given): 4374
Likes (Received): 1743
You also want to get to that flywheel and see if there is a ring gear on it for the starter to engage with.
Likes 132619 liked this post
post #4 of 14 Old 12-07-2018, 06:07 AM
Thanks (Given): 7
Thanks (Received): 32
Likes (Given): 411
Likes (Received): 116
kiss is right! sometimes the engines were spec'd without a ring gear for the starter on the flywheel , make sure before you jump
132619 is offline
post #5 of 14 Old 12-07-2018, 07:58 PM Thread Starter
Thanks (Given): 80
Likes (Given): 277
Thanks for the replies everyone....you've saved me hours of frustrating searching!
I'll be sure to check for the ring gear before ordering.
post #6 of 14 Old 12-13-2018, 08:43 PM
Thanks (Received): 26
Likes (Given): 113
Likes (Received): 68
Figure out what the comparable Ariens model is and look for a starter using that!!
As well as any parts you need because that brand is much bigger and parts are cheaper and more plentiful if not branded as John Deere. In fact I bought about $160 worth of parts to fix it up and everything but the $15 for two belts was a Ariens model search.
Fyi I just got a 1997 1032D with the HMSK100 tecumseh engine and found a starter on ebay for $52.44 shipped from heart-landstarters and it bolted right in and cranks over the 10hp engine easily!
notabiker is offline
post #7 of 14 Old 12-14-2018, 09:42 AM
Likes (Received): 40
Wouldn't you need a new flywheel/recoil cover?
Both my electric start Tecumseh motors HS50 and HM80 have a bump out for the starter.
I know some of the HS50 without electric start do not have the clearance for the starter as they lack the bump in the cover?
Red
bigredmf is offline
post #8 of 14 Old 12-15-2018, 01:21 PM
Likes (Given): 113
My 10 hp tecumseh just had a tin plate covering the hole where the starter pinion goes through. Remove a philips screw and the plate comes off, though I had to remove the gas tank lower bracket to get the bolts in for the starter.
So make sure you have the hole/spot for the starter and that there are holes in the crankcase to mount it. Mine also had the holes in the top of the starter cover to mount the push button/plug in for the electric starter.
Take some pictures with the sides of the engine at eye level (like you're as tall as a two year old) and angled towards the recoil from the bucket side to see if you have to get more than just a starter
post #9 of 14 Old 12-16-2018, 09:23 PM
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 269
That is a JD build 1032. Mid-80s.
GoBlowSnow is offline
post #10 of 14 Old 12-16-2018, 09:26 PM
Likes (Given): 57
This is an Ariens built JD1032D (D gives it away as Ariens built)
https://i.ytimg.com/vi/rsvcZZe3VYM/maxresdefault.jpg
This is a Murray built JD1032- Model is TRS-32. TRS gives it away as a Murray built. (piece of crap) (I have one so I can say that!)
https://images1.farms.com/ufe-images...s/175827-1.jpg
